Question about Amana NDG8805A Gas Dryer
Dryer does not stop. all cyles dry hot!!!!!!!
  • Amana Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Dryer shuts off during cycle
DOES IT START RIGHT AWAY OR ABOUT AN HOUR LATER? IF LATER U MAY HAVE A BAD MOTOR WINDINGS PROBLEM? OR A BAD CYLING THERMOSTAT, MOISTER SENSOR NOT DETECTING DRYNESS OR DETECTING DRYNESS WHEN ITS NOT DRY?
Feb 27, 2015 | Whirlpool LER5636P Electric Dryer
My Admiral gas dryer stopped heating up. Model# AOG7005AWW. I have already cleaned all vents. Only cold air blows out of the back tube, cold inside the dryer. Before was taking 2-3 times a cyle to dry for...
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Dryers
My dryer doesn't get hot enough to dry clothes.
Try changing the ignitor...
Here is a tip that will help to explain why I think this is probably your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
Not heating and drying clothes properly takes about 2hrs to dry jeans??? what is the problem
frist check the vent if this is to difficult for u pull vent hose from dryer run dryer with load 45min normal dry time . longer for jeans 60- 70 mins. if this works. u have vent problem. if not remove back of dryer replace cyle tstat this is one closer to vent duct problely 4 wires
Oct 26, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
My dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
My atlantis MDE7600ayw is taking two cyles to dry
Your heating element is going out. If your dryer is still under warranty, contact the manufacturer and let them know what's going on. They should send you a replacement part, or should send a technician to fix it.
Jan 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Amana NDG8805A Gas Dryer Logo
32 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
