Question about Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television
I have black dots that almost cover the entire screen when I first turn on the TV that later turn to red dots and clear up after about 30 mins. What could be causing this?
  • rjamessc Aug 30, 2010
    Is the fix expensive?
    Genius:
  • Sony Master
  • 1,689 Answers
Usually caused by the main driver board for the panel, or on the back-plane of the panel. The common solution is to change the driver board. If this does not work, then the panel would have to be tried.
It is possible in some cases the fault could be caused by the interaction of other boards, or can be on more than one of the boards. The factory service will use the process of elimination to locate the fault.
Service on these sets is done with board swaps, just like with computer service. Once the board is exchanged the new board may require some calibration to be at specs.
Jerry G.
Posted on Aug 30, 2010
There is a red dot near the center of my Vizio tv screen, what is it?
if just a single tiny dot it is a bad or defective pixel in the front panel-usually there from first time the unit is powered up but from a distance may not be noticed--almost never gets worse or increases in size. Unless set is under warranty do not worry about is as a Panel(entire front screen unit) usually costs more to replace then the entire TV.
Apr 08, 2012 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
My Samsung32'' resets to default settings every 30 mins!
Hi reset the tv and put it in to home mode!!!!
Shop mod resets tv settings every 30 mins
Apr 13, 2009 | Samsung Televison & Video
Screen is out on a LG 42" DU-42PY10X plasma hdtv
I think I can solve this. Am going to buy parts and see.
Feb 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Plasam with black screen with red and green snow
i have the same tv with the same problem, did you find out what it was?
Jan 24, 2009 | Toshiba 42HP82 42 in. Plasma Television
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television Logo
123 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
