Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Can you replace just the rear bearing on a frigidaire "gallery" series front loading washer without having to replace the rear drum half as well. if so where can i buy just the bearing?
  • Frigidaire Master
  • 2,605 Answers
Hi, Welcome to FixYa. I theory...yes it can be done. The problem lyes in 1) finding just the bearing & seal... and 2) the shaft of the inner stainless steel basket is likely going to be badly worn or "scored" as a result of the bearing failing. I always replace the entire assembly, but if the bearing and seal where available seperately it would still require the inner basket and a complete tear-down and just as much labour ( or more likely ) it is less expensive to do the complete assembly. I'll leave that with you, let me know if I can assist you further. Macmarkus :)
Posted on Aug 30, 2010
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum is loose, struts maybe? springs?frigidaire gallery front load.
this could be the bearings,if you feel a knocking noise when lifting the inner chrome drum up and down then its the bearings,
Jul 06, 2009 | Frigidaire GSTF1670A Front Load Washer
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Access to parts in washing machine
2 men 2 hrs minimum tub halves are bolted together and entire assembly will need to be removed bearing is not a service part entire rear shell will need replacing and probably basket also due to shaft scoring better ck for warranty
Jun 04, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
May 16, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
381 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
