Question about Samsung Dryers
I HATE THIS MACHINE!!!!!! It is one year old, has done about 50 small loads, and every one comes out DAMP. Just tried to dry 3 regular bath towels(not bath sheets,not beach towels,3regular cotton bath towels) and spent 3 hours on the heavy duty settin g and they still came out damp-what a waste of my time...is this a lemon,or is the entire product line lacking...oh yes,did I say it cost $1,499.00 plus $250.00 for the stand ,plus 10% sales tax !!!!
  • barbaravash Aug 31, 2010
    Thanks, I've scheduled a repair person from Sear's(where I purchased this machine)...somehow I'm not comfortable with them as a company or as a repair company, but I'll show them this email when they arrive Friday...any other suggestions? Many thanks.
  • 10,319 Answers
Let me ask you upon hooking this dryer up did you install brand new vent work for the exhaust vents? If no they need to be replaced if they are the cheaply made expandable aluminum foiled tubing. If the tubing is made of sheet metal, clean it out thoroughly by taking the tubes completely apart. Most people do not know for the past 20 years the good old government issued manditory moister sensors installed into all dryers to prevent house fires. These sensors detects any lint build up and puts the heat into the check mode. You will initially get heat for a minute or so and that is it if this is your problem
10% is for good old Sam you know
Posted on Aug 30, 2010
  • frank thomas wilson
    frank thomas wilson Aug 31, 2010
    No other suggestions at this time. I will check back and see if you have any other imput from what the service repairman finds out. since its fairly new it should work very well although you never know sometimes
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dishes do not dry
Hi..
Try these..
1.Check that you are using a regular machine cycle, not a short or special cycle. 2.There could be insufficient water fill or pressure. Run your dishwasher when other household demands for water are low (i.e.k, laundry or bathing). 3.This may be due to improper loading of dishes. Check that your large dishware doesn't block the detergent dispenser or water spray. Check your dishwasher manual for proper loading techniques. 4.You may have used too little detergents. Use Finish tabs for even dosing. 5.The spray arm may have been blocked, please ensure that the spray arm can rotate.
please rate my suggestion
Apr 13, 2009 | Dishwashers
Poor drying quality
repl/ thermistor, also remember that these dryer have smart sensor drying,, there are 2 metal strips inside use rubbing alcohol and clean this will fix your probablem
Jan 02, 2009 | Kenmore Elite HE4 Electric Dryer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
70 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
