My Rinnai is only 3 years old and just recently it is running out of hot water. It has been taking about 10 to 15 minutes for hot water to return. We have well water and we are unsure what the problem is. Any suggestions?
    Novelist:
  • 120 Answers
The Rinnai relys on good water flow to fire it up. In saying that it runs out of water; thats actually not possible. The Rinnai just heats up water as it goes. Usually fault for installs on bore or well water is a problem with water flow. Causes are blockeed filters or you water pump from the bore starting to fail. I would expect you to have a large filter somewhere on the water line from the well. Try and find it and clean it our. The Rinnai also has a filter. It,s like a plastic round shaped nut just under the heater on the miidle connection. Turn the water off first, it should almost unscrew by hand, take it out and clean it (make sure you don't drop the O ring on it. Also some tapware has water filter right in the end of the spout, check these too. After you tried all this focus on the pump. Make sure no ther water id flowing, try the hot tap and see if it works. Do the same but slowly turn on a cold tap, slowly increasing the flow. Have someone out by the heater and see if the heater shuts down at any point. If it does it could be the water pump at fault. From what you have told me and am certain water flow is the culprit here. Really focus on anything that might lessen the flow before you start messing with the heater. Best of luck.
Posted on Aug 30, 2010
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
"Infinity 20" probably 8yrs old now. Recently started making a humming noise whilst in use. The noise continues 15secs or so after hot water tap has been turned off.
Sounds like the diaphram in the gas control valve which is not replacable. You would have to replace the gas control valve and I would also suggest replacing the thermocouple. However since the heater is 8 years old you may think about replacing the entire hot water heater. Depending on how much water has gone through it in these past 8 years it will probably rust out soon and then you will be dealing with a flood.
Good luck,
Marty
Nov 08, 2013 | Rinnai Water Heaters
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Hello, I recently had a Rinnai tankless water heater installed. The old water heater was in the garage. The new tankless heater is installed outside, and is about 25 feet away from where the old one...
I agree with you. The foam insulation should only be on the Hot Water side. The cold water side doesn't make any difference, as that temperature rarely changes in California.
Hope this helped you AK, thanks for choosing FixYa.
Aug 10, 2011 | Heating & Cooling
My Rinnai is only 3 years old and just recently it has been running out of hot water for 10 to 15 minutes long intervals. We have well water and I am wondering if that has something to do with it. Kind of...
The Rinnai relys on good water flow to fire it up. In saying that it runs out of water; thats actually not possible. The Rinnai just heats up water as it goes. Usually faults for installs on bore or well water is a problem with water flow. Causes are blocked filters or your water pump from the bore starting to fail. I would expect you to have a large filter somewhere on the water line from the well. Try and find it and clean it out. The Rinnai also has a filter. Its like a plastic round shaped nut just under the heater on the middle connection. Turn the water off first, it should almost unscrew by hand, take it out and clean it (make sure you don't drop the O ring on it). Also some tapware have water filters right in the end of the spout, check these too. After you tried all this focus on the pump. Make sure no ther water is flowing, try the hot tap and see if it works. Do the same but slowly turn on a cold tap, slowly increasing the flow. Have someone out by the heater and see if the heater shuts down at any point. If it does it could be the water pump at fault. From what you have told me and I am certain water flow is the culprit here. Really focus on anything that might lessen the flow before you start messing with the heater. Best of luck.
Aug 30, 2010 | Water Heaters
Rinnai XR 20 - water temperature varies hot - cold - hot etc during 4 to 5 min shower
your gas supply may be to low to keep the unit firing while you are showering...especially if you have other gas appliances running while you are using the unit.
If this is happening after someone else has recently used the unit....then it may be a problem that some call stacking. The unit works on flow....not sure about that unit but they usually take between 1/2 - 3/4 gallon to turn the burner on. If someone recently used it and then you get in the shower...you will get the hot that is already in the line but then it takes that initial amount to fire again, thus loading the pipe with cold water.....it then comes out on you followed by the hot that has finally entered the line. Once it is past that point there should be no issue, unless it it a gas problem like I mentioned.
Oct 24, 2009 | Rinnai Water Heaters
Takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
Jun 12, 2009 | Rinnai Water Heaters
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
