Question about Refrigerators
I have a frigidair gallery refrigerator that I have had for 2 months. It has the water, cube and crush ice on the door. It has slowed down to making ice only once a day.
    President:
  • 3,773 Answers
Check temp. Should be 0-10 degrees<br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Posted on Aug 31, 2010
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
I have a Frigidaire Gallery 27.8 Cu. Ft. French Door Refrigerator that is about two weeks old. The ice maker started only dispensing crushed ice and not cubed whether or not the light indicator is on...
This is a manufacturer issue that needs to be addressed by the company who sold or made it. Phone:
1 (800) 374-4432
Monday - Saturday
8:00 a.m. - 8:00 p.m. (EST)
This is their number. Call them first. It is a good company. I myself have their products. Let me know.
Nov 13, 2013 | Refrigerators
Ice maker only producing crushed ice, only I have it set on cube. I have taken the tray out twice and dried. Still only crushed. This is a Frigidaire Gallery Series fridge.
We had this problem and have visited several friends houses in our neighborhood who all have appliances of approximately the same age, 6 to 7 years old and found this to be quite common.
The solution to this specific problem was rather simple, and has proven effective on several different brands, to the relief of many befuddled husbands and frustrated wives and now happier children.
Though the mechanism is in a slightly different location on some models.
I removed the ice hopper and looked in the back of the freezer and found the steel drive prongs that power the feed screw inside the ice hopper.
An inch down and a few inches to the right of it I found the mechanism that actuated the arm to open the chute for cubes or keep it closed for crushed ice. (on the Frigidaire Gallery Series)
I held the interior light switch closed and had someone push the ice lever on the outside and observed the drive prongs turn, but the mechanism that actuated the arm to open the chute did not move.
Stuck my finger in there and pushed it upwards manually and after a brief moment of resistance it moved freely.
Re-tested the operation of the mechanism that actuated the arm to open the chute, and it now opened when the ice lever was depressed and set to cube, and stayed closed when it was set to crush.
With the money we saved on the service call, I took the family out for chinese food.
Mar 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire model glrs267zcwi side by side. Crushed ice comes out when either the crushed or the cubed button is depressed. How to fix it please?
It sounds like the water line to the ice maker is partially obstructed (probably semi-frozen) and the unit is making smaller than normal ice cubes. This causes the ice ejector to "shatter" the smaller cubes, producing the appearance of crushed ice.
The easiest thing to try is make sure the water line connection inside the freeezer isn't frozen. A hair dryer can be used to thaw the inlet to the ice maker, but just be careful. Remove some of the product in the compartment so you have enough room to work.
Dec 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker only dispenses crushed ice
You guys are great. I just pushed down on the lever in the back and once again I have cubed ice!! Thank you!
Aug 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Crushed ice mode seems stuck - want cubes but keeps crushing.
jeff, at one time the ice bin was removed and there is a rod on the bottom of the bin remove the bin and you'll see an opening where the arm will fin the square plastic looking assy is probally stuck in the up position pull it down with you finger and reinstall the bin the it should work
Aug 19, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Door ice dispensor will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
