Question about Whirlpool Duet GHW9150P Front Load Washer
What is the best way to quiet machine during spin cycle?
    President:
  • 2,702 Answers
If the washer is very noisy in spin mode its likely the drum bearings have worn out,,,try this out first
open the washer door and get hole of the drum at the top ,,now lift it up a little if there is a lot of lift and it drop with a knock when you let it go this is the bearings worn out,,also spin the inner drum with your hand if it makes a grumbling noise its bearings
Posted on Aug 30, 2010
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Maytag quiet series 100 noise during washing
Roaring noise must also come during the spin cycle I suppose...it seems your bearing and or drive belt/gear is causing you this noise. To fix this, you would need to completely disassemble the washer and inspect the bearing and or drive box that activates the turning motion. It is a large job.
Dec 02, 2013 | Maytag Washing Machines
Thunping or banging noise during wash cycle may tag MVWC300VWo quiet during spin
You will need to pull the basket and check the drive block.
Here is a video to show you how to get to the drive block.
Dec 03, 2012 | Maytag Washing Machines
Counter weight on front load machine is crumbling to pieces and machine makes loud noises during spin cycle
Cindy, you might want to check the gears in your machine. I had a similar problem and it turned out that the gears are made of a plastic/nylon material and they deteriorate pretty easy, making the washer make loud noises. Took the guy who fixed mine about 20 minutes and then it was nice and quiet again. Good luck.
Nov 27, 2011 | Kenmore Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
