Question about Dryers
I just need a picture of what the power cord should look like when its properly hooked up to the back of the dryer or how it should be. Thank you
  • 10,319 Answers
Any picture will not help for the wires must be measured with an OHM METER to find which wire is which end to end
Posted on Aug 30, 2010
Install power cord dryer
Before you change wiring check and see if its a proper cord for a 220 hook up. most three prong are for a 110 hook up. Ask an electrician for advice so you don't have a fire or kill yourself. Most Dryers are 220
Feb 25, 2014 | Dryers
I just got an LG TROMM DIE2512W dryer. I have a power supply cord with three cables (green, black and white) good for 120v.15amp. The green cable is my ground. I connected the black cable from the power...
If you have a red wire then the dryer is a 240v dryer and needs a 240v 30 amp circuit...
Here is the manual for your dryer and it shows the hook up you need on page 17...or part 5 of the manual...
Click here
heatman101
Jul 31, 2011 | LG DLE2512W Electric Dryer
NEED TO KNOW HOW TO HOOK UP A 4 PRONG CORD TO DRYER WHAT COLOR GOES WHERE
The following link explains how to properly connect a 4-prong power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this helpful.
Oct 07, 2010 | Kenmore Dryers
Our dryer model wed6200sw1 will not power up. my brother inlaw installed a 3 wire power cord when helping us move. there is a white wire that hangs loose in the housing that I believe is a nuetral ground,...
This is tough to say without being their.. But lets try...You need to hook up the power cord correctly before doing any other diagnostics...On the dryers terminal block you should have a black on one side, white in the center, and red on the other side THE POWER CORD WIRES HAVE TO BE HOOKED UP THIS WAY. when checking voltage at the back of unit make sure its 120 volts from center to right side , and 120 volts from center to left side after this is correct we can diagnosis from their if its not working right.......
Sep 01, 2010 | Dryers
How do i hook up the electrical cord properly?
May 08, 2010 | Whirlpool WGD5300S Dryer
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
My dryer all the sudden is blowing the fuse at the panel. It runs for a short time and then blows the fuse. Sometimes it just keeps running and doesent blow the fuse. It is hooked up properly and has never...
UNPLUG THE CORD then,.,,,maybe the cord hooked to the dryer terminal block and just follow the cord to the unit and take off the axcess panel to power cord hookup is shorting out and needs to be replaced being hooked up properly is why its the first place to look for its
Aug 26, 2009 | AEG Dryers
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Wireing an a/c plug to a samsung DV316LES dryer I have Black, White, and Red wires coming out of the dryer. the plug I purchased came with Black, White, and Solid Green wires. I am sure it goes color to...
unless you have an a/c outlet close to your dryer the you wont be able to use an a/c cord. also the cord for an a/c i usually rated for 20 amps and your dryer needs to have a 30 amp circuit.
i would not suggest using this cord as it will overheat and probably cause a fire in your house.
if you think the cord can handle 30 amps, then you need to make sure you hook up red and black to the power sides, white to the neutral and green to ground.
seriously, just go back and get a dryer cord that will match the outlet that is close to your dryer.
draw a picture of what the outlet looks like, ie: the position and angle of the plug slots and go back to the hardware store and find the right cord.
it will work properly and be safe to use.
Jan 07, 2009 | Dryers
I have a maytag dryer Model #: MDET236AYW and I would like to change out the existing 3-wire dryer cord to a 4-wire dryer cord. Presently there are 2 wires attached to the dryer frame and 3 wires connected...
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Maytag Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
