Question about Jenn-Air Refrigerators
Freezer is working properly however my refrigerator is not cool enough.Is this a easy fix
  • Jenn-Air Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 31, 2010
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
Ge TFX24S refrigerator does not get cold enough
Your Defrost electrical element (heater) is blown, you will need to buy a new defrost heater. Your evaporator coils in your freezer section is froze up (no air flow)...soild ice, thus you're not cooling down properly. You will need to defrost and then underneath the coils you'll find the glass tube with defrost heating element...you will need to replace this part (entire glass heating element)...it's DIY fairly easy to get at.
Nov 17, 2013 | GE Refrigerators
My freezer is working but the refrigeration part is not cooling enough
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start.In your case freezer is cooling, then freezing, but its not defrosting.Thats why fridge section is not cooling.------- Click this link below and follow the troubleshooting:---- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech/.
Aug 19, 2011 | Amana ARB1917C Bottom Freezer Refrigerator
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
The refrigerator is cool, not cold, but the freezer is still freezing. What is the problem? Is this easy to fix?
The problem could be many things...and is there ever an easy fix??? :-)
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | Kenmore Refrigerators
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is cool but cool enough and so is my freezer cool, but not cold enough to freeze anything. It seems that the motor is running.
Your refrigerator's defrost heater is not working. The frig's cooling coils are frozen up because the defrost switching unit needs replacing. It is a cheep fix. Call a refrigerator repairman and have it replaced. Max cost is around $ 100.00 mike micmor68@gmail.com
to prove this turn off refrigerator a couple of hours with the doors open and you will notice water appear on your floor as unit defrosts and it is more water than your defrost pan can hold. As it overfills it will spill over onto your floor. If you turn it back on it will work properly for about two weeks and it will start the problem again. mike micmor68@gmail.com
Oct 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigeraotr is out but freezer still works
doesnt make adiff how you loaded freezer, shouldnt affect fan operation anyway. if you have a meter you can check for proper voltage(110v) to fan wires and if you have power youll need to replace fan, easy enough to do just a few screws and about $50.. part number 5304445861.
Oct 21, 2008 | Frigidaire FRT21H8 Top Freezer...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
67 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
