Question about Refrigerators
The refridgerator side is not working - Refrigerators
  • Refrigerators Master
  • 3,083 Answers
Here is a general troubleshooting guide, when the refrigerator isn't cooling:
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itsnotcool
You can find your type of refrigerator (side by side, etc.) and that will give you more precise information.
Also, if you go up to the following site and enter your model number, they may have diagrams and troubleshooting tips for your unit.
http://www.appliancepartspros.com/
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 30, 2010
Refirdgerator won't cool proprely on refridgerator side
Hi SN,
This could be a couple of things, but you should check for evaporator icing, even though you said the freezer is working and the defrost control appears to be ok. If the evaporator is iced up, no air willl flow into the fridge section even if the fan is running.
You can also check the damper control board. I am sending you a link that shows a complete breakdown of your appliance. I do not work for this company nor am I affiliated with them in any way. They also have a troubleshooting section and contact information. See:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5121995&diagram_id=29020886#d29020886
Aug 18, 2012 | Refrigerators
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
