Question about Sony Playstation 3 (PS3) Console
I have a wireless router for my PS3. When I test for a connection everything succeeds until I get to the Playstation Network then it says failed. Whats wrong?
Same problem with me. Worked for 4 months without an issue. Connects and get IP address, then fail at Playstation Network.
Posted on Aug 31, 2010
I use to have the ps3 hooked and on a new service moved forgot everything and trying to connect to the wireless interent and it keeps popping up psn failed
Everytime you disconnect from a network you ll have to go into the network settings again to reconnect. Find your wireless connection on the list, select your security, enter password and then hit "test". If all credentials were correct, it will quickly breakdown the connection attempt for you, showing you where the connection succeeded and where it failed to better triangulate the issue. If all connections succeed during the test, simply go back to the main screen and sign on. Hope this helps.
Apr 23, 2015 | Sony Playstation 3 (PS3) Console
Was the webkey for my ps3 and how much is a
There is no "webkey" for a Ps3, I have a slimline 250gb and there is no key that you need to know about. If anything you have a playstation network login with a password that you set yourself or when you set up a wireless connection you need your WPA or WPA2 password for the connection so that you can use your in home WiFi.
a decent router to buy are Linksys, Belkin, and Netgear. I have a Netgear or a Belkin and its just a average house wifi network router that cost me about $50 at Bestbuy.
If connect it just follow the directions and use the windows network wizard to setup a wifi network. just be sure to remember your password for your wifi!!
When its time to connect your Ps3 just go to settings>Network settings (very bottom) > then I think its Internet connection settings> Easy>Wired or Wireless> Scan> select the right one>name it or dont> put in the password> make sure everything is correct> test it> Then if your test succeeds you'll be ready to go!
check out my site! http://ctrlr4repair.webs.com!!
May 05, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to psn. But i can to internet. :(
One reason this may be happening is having the media sharing option on. Some routers can't handle all the requests the ps3 sends while having this option on. You're using a wireless connection right?
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
How do i hook up my ps3to wireless router
First you'll need to contact your Router Vendor
And disable The firewall in the Router
Then On the PS3
Goto settings -> Network Settings -> Internet Connection Settings
If its asking for confirmation Select Yes
Select Easy
Select Wireless
Select Scan
Select the Name of your Network
Select the Security type and type the password
Save the settings and test the Connection
If the Test Succeeds then it Will Work
Jan 11, 2010 | Sony Playstation 3 (PS3) Console
The connection to the playstation network fails
sounds like a problem with the wireless network card.
Go thru these instructions to get your ps3 to recognize your wireless router, if it doesn't work then you know that your wireless network card in the ps3 is bad:
http://www.ehow.com/how_2291028_connect-wireless-internet-playstation.html
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Internet connection fails on ps3
im really only experienced with xbox but your best bet is to call sony for help.
Jan 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Cant get my ps3 to connect to internet through my wireless router
Assuming the media test works (So the cable/wireless connections are OK) then it's possible that you're out of available IP addresses in the router. It shouldn't be a problem (Most router configs allow for over 250 IP addresses), but it might only have limited leases.
Try switching everything off (Except for the router), restart the router and then try the PS3. That should rule out a problem with DHCP
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Internet Connection
On the X-Cross Media Bar, (the menu that comes up when you turn on the PS3) under "settings", go to "Network Settings".
then go to "Internet Connection Settings". select "yes".
go to "custom", "Wireless", "Scan".
If your network is not listed, move your PS3 closer to the Wireless Access point.
Select your Network and enter your password (if it needs one).
select "automatic" for everything.
select "Test Connection".
the "Obtain IP Adress" and "Internet Connection" should say "Succeeded".
If not, contact your system or network administrator or a teacher that knows a lot about computers.
Aug 17, 2008 | Sony Playstation 3 (PS3) Console
Heeeellllllpppppp!
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
