Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-air svd48600w model. End caps for front control panel have been discontinued and I need to replace them. Can't find them anywhere. Anyone have any bright ideas? John Darnall
  • 10,319 Answers
Try these 3 websites below
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=488456&ST=PBM
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43495
http://www.partselect.com/MultiModels.aspx?ModelNum=SVD48600W&searchTerm=&RefineSearch=0
Posted on Aug 30, 2010
How do I find a discontinued part for my Jenn-Air Refrigerator Model # JCD2389GES? I need a specific part # 61005056 (black Escutcheon)
if the line is discontinued, that means NO ONE makes it anymore, sorry but there is no way around this one-buy a new fridge.
Jan 05, 2015 | Jenn-Air Refrigerators
Jenn-Air W241-C wall oven
Unless you can find one in a used oven, I don't know. Jenn air website says they are discontinued and offers no substitute part.
Jul 17, 2014 | Jenn-Air Ovens
Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Jan 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Jan 01, 2010 | Kitchen Ranges
Jenn-Air svd48600w chiming and displays f7 on control panel and the buttons on the panel no longer work. The only way to make it stop is to flip the breaker, then it starts again after a few minutes. For...
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4090068
whats happening her is that you are getting a stuck button error
it keeps happening because when you reset, the stuck button is still stuck and it gives you the error again
Maytag suggest replacing bothe the touch pad and the erc, but I have onle had to do both twice in the last 15 years,,,,
both had water damge
since you dont mention water , I would be willing to guess the part at the end of that link should be the only one you need to replace
Oct 17, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Our Jenn air svd48600w has had the clock control panel replaced 3 times. The replacement lasts about 6 months and then the alarm starts beeping again. We have to unplug the control panel to silence the...
I would recommend putting 'surge protection' on the house breaker panel. I would suspect that you are getting power bumps that kill the EOC. Do you have power outage and lightning?
metertreater.com has some good stuff. Have an electricaina install it at the meter. Or you can put it right in the main panel yourself if you know how.
Sep 25, 2009 | Kitchen Ranges
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Jenn-air svd48600w
If your display has gone dimmer and dimmer or just gone out it is probably the display board. There are a few capacitors on the back of the board. There is one that is 68 Microfarad 35 Volts. It is common for this one to go bad. I replace it with a 68 Microfarad 50 Volt rated one and that usually solves the problem.
Mar 03, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
78 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
