Question about Sony Ericsson Stereo Bluetooth Headset HBH-IS800
My hbh-is800 is not powering on. but charges fine
I have a sony ericsson KRY 901 HBH-65 and i don't know how to use, i want to know how.
Turn Off, Hold the power button for 5 seconds till you get red/green flashes, its now in pairing mode.
For the user manual, look up HBH 65 as its not listed under KRY 901
Aug 11, 2010 | Sony HBH-65 Professional Headset
How can I fix sounds delay on my Motorola HT-820? I just recently bought this items and I found out that there is a sound delay for 5-10 sec. Is this normal?
Some delay might be normal, because your phone requires some time to encode the A2DP stream, and your stereo headsets will also add some more to the total delay time, since it has to decode that stream, but it all depends on the processor's hardware and power, the application being used to play the media file, the codecs used, the headset's quality, etc. So, in general, A2DP might not be the way to go, whenever image synchronization is required, like watching movies, music clips, TV streams, etc. Wired headsets would be a better choice for such cases, instead.
In can tell you that in my current phone,an Acer Tempo M900, if I run WMP to watch a MP4 encoded music clip, with its audio being streamed via A2DP to my SE HBH-IS800 stereo headsets, the sound delay might be considered negligible. I'm pretty sure newer phones would perform even better. But I remember having experienced heavy delays with other environments in the past.
Just my 2 cents... Carlos
May 28, 2010 | Motorola Mobility HT820 Wireless / Cable...
I'm using a HTC Legend and would like to sync it with my IS-800 but the phone can't seem to find the headset. I thought bluetooth headsets were more or less universal. Is there anything i can do?
For some phones, provided that both its bluetooth radio and a nearby BT headset are turned on, and the headset's MFB (for the IS800, the only button it has) is briefly pressed. The phone then prompts the user to pair with the headset. For others, the headset must be put in pairing mode, and the phone must be made to search for it. If this is your case, press and hold the IS800's button until the right earpiece's led flashes red / green (the white led, next to the mic, will flash too). Then, you must start your phone's bluetooth settings, and make it search for the headset. In both cases, if you are prompted to enter a pairing code, the IS800's is '0000' (four zeros).
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 26, 2010 | Sony Ericsson Stereo Bluetooth Headset...
N97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
Sony blue tooth hbh-pv703
you need to press and hold the buton until the light stays on to get into pairing mode, when on, go to your phones bluetooth settings, search for bluetooth devices, then when it finds the headset a code will be requested, this is 0000, enter this and the light will flash intermittently telling you its paired with your phone.
Sep 03, 2008 | Sony Ericsson HBH-PV702 Wireless Headset
How to add bluetooth head set HBH-iv835
yea how ya goin mate its simple i had one of them, just go in your menu go in your bluetooth setting and search for device but make sure your head set is on and fully charged
Mar 29, 2008 | Sony Ericsson K800i Cellular Phone
Can't charge the hbh-608
The problem is the connection points. Take a pecil reaser and rub it back and forth across the coper strip. Do this to both the earpiece and the end of the charger chord. This is what fixed it for me.
Aug 16, 2007 | Sony Ericsson Akono HBH-608 Wireless...
Sony Ericsson Stereo Bluetooth Headset HBH-IS800 Logo
59 people viewed this question
Top Sony Ericsson Radio Communications Experts
yobo007
yobo007
Jay Finke
Jay Finke
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
