Question about Microsoft Windows Vista Ultimate Edition
My hard drive does't store any data, some bipping sound comes out from my hard drive.It show all the information regarding HDD for eg. 80GB,model-ST380011A etc. please solve my problem
  • 26 Answers
Your heads are bad. If the Windows Install disk does not let you format (Or disk manager if it is a secondary HD) then you need to contact the manufacturer to RMA the drive
Posted on May 08, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
HOW TO SET ORIGINAL SIZE OF HDD SEGATE BARRACUDA ST380011A THAT I WAS SET TO LIMITED SIZE I.E. 32GB NOW I WANT SET IT TO 80GB WHICH IS ORIGINAL SIZE.
you could do it by reformatting your hard drive which would mean loading your operating system again during the formatting process you will be given the option to select a partition or to select another or resize or download some software either partition magic which enables you to rezize your your already partitioned hard drive without losing any of you data http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Aug 24, 2012 | Seagate BARRACUDA Computers & Internet
How can I convert a Seagate Barracuda 7200.7 (Model st380011a) to an external drive with usb?
BUY A HDD ENCLOSURE (http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=2777&name=Hard%20Drive%20Enclosures)
Apr 09, 2012 | Seagate Barracuda Model ST380011A 80GB IDE...
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
My seagate barracuda 7200.7 st380011A 80gb when i use it as primary haerd dist operating system is not supporting it but when i use another hard disk as primary and it as secondary it is properly working....
i think you must place a jumper on the back side of the hdd.
If there isn't any jumper, it is a "slave".
When you place a jumper on the correct spot, the hard drive will become the master hdd. The position of the jumper can be found on the hdd itself.
Search for "master" and put the jumper there
Jun 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Trouble in HDD
I dont think its supposed to copy data in a boot process
copying and booting are totally different processes
Did you mean to say you have hdd issues
Feb 28, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hard disk is not detecting
hi, you should try downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/
and booting off the floppy disk it creates will tell you if theres a problem with the drive and will probably fix it for you..
Happy New Year
John
Nov 18, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
