Question about Nikon D90 Digital Camera with 18-105mm lens
I get the F-- message when I turn it on. Sometimes when I fiddle with the camera it works. When it is working I also get an ERR in the top left and a CHG in the bottom right. Battery is full
  • 6,831 Answers
Hello
The link below should be of help, Click HERE to navigate to the page.
Let me know if this not useful, so that we can try something else.
Kind regards
Andrea
Posted on Aug 30, 2010
Nikon d80 err code
While I can't speak specifically to the D-80, my D-90 users manual say the ERR message indicates a camera malfunction and can be cleared by tripping the shutter. The only way I can do this on my D-90 is to turn the camera off and back on. Sometimes, but not often, I have completely remove the battery and reinstall it. The users manual also says that if the problem persists to contact a Nikon service center. I suggest you contact Nikon support at www.nikon.com before you consider repairs.
Aug 28, 2014 | Nikon D80 Digital Camera
ERR comes on screen...
Pull all the batteries, wait 30 seconds, put in a completely different card, put batteries back in and turn on and format the card--sometimes works
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Will not tke picture an err message flash at top of screen
Hi anotherie14, the ERR is not a good thing. Try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go to Nikon.
Jun 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err problem
The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
May 12, 2010 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80 camera that is about 1 year old. I has worked fine until about 6 months ago. Sometimes when I turn it on and press the button to take the picture nothing happens. I have to wait awhile...
Are you getting a Err message? If so The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Mar 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Nikon D50 Body issue
Sounds like your mirror is stuck up or partially up. I'd take it in to be repaired to be safe and so you don't have to fiddle around inside it.
Mar 06, 2007 | Nikon D50 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
200 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
