Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice builded up in back of freezer - GE (PSS26MSRSS) Side by Side Refrigerator
    President:
  • 3,773 Answers
It is a defrost problem since the ice that freezes on the freezer coils<br />is not being melted by the defrost system.<br />There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.<br /> Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info Also check evaporator fan in freezer If this was helpful please rate me <br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas <br /><a rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>"
Posted on Aug 31, 2010
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Noisy freezer, could be fan or condenser
I wouldn't defrost it. It could be a couple of different things causing this, from a bad defrost thermister to cubes overflowing out the back of the ice bin. Try removing the ice bin and clearing the cubes off of the dispenser motor cover. The fan will eventually sling the ice formation off.
Feb 14, 2010 | GE Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
