Question about Whirlpool 3.2 cu. ft. Plus Washer
The water in my washer is not draining, it seems to have done its first wash cycle. I have tried to push down on the lid and have also tried resetting the button. Will I need a technitian or is there something else that can be done? I have a whirlppol Super Capacity plus washer (Commercial quality). Thank you, Ingrid Lamberty
  • ingrid_lambe Aug 30, 2010
    Thank you for your solution. I will only be able to try this solution this afternoon when I return home, I will be in touch to advise whether or not I was successful.
    Kind regards,
    Ingrid
  • Whirlpool Master
  • 43,501 Answers
There are many thing that can cause your washer not to drain...the lid switch you already kind of checked but it really needs to be checked with a meter...the other thing you can do is check to make sure nothing is clogging the drain pump...many washers have a filter and I have gotten quite a bit of money out of them... :-) Amoung other things I'd rather not talk about... :-(
Here is a couple of tips that will help you trouble shoot your washer...I have includes both top and front loader cause I don't know exactly which you have... also it includes apinning problems cause they are often interelated...
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 30, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 30, 2010
    Okay, I am on the east coast so I may be a sleep, but I will get back to you if you leave me a message...I am self employeed doing al sorts of work,,, I do most anything... and will try to check in the morning before I take off...
    heatman101
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool washer will not drain the water.It seems to work fine at all other stages of the wash cycle.When it gets to the stage when it is supposed to drain it does not drain and you hear a buzzing type...
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Jan 10, 2011 | Washing Machines
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 22, 2010 | Kenmore Washing Machines
The washer only goes thru the wash cylce. It will not rinse or drain the water
It sounds like you probably have a defective lid switch. Try pushing it down with a pen or something if you can see it, if the unit will spin. It will not go into a drain cycle if the lid switch is defective. Hope this helps MJ
Jun 09, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a kenmore washer model #23832100. It will
Yes....the lid switch is broken...will need to be replaced.
Jun 10, 2009 | Kenmore 22422 Top Load Washer
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Whirlpool 3.2 cu. ft. Plus Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
