Question about Visioneer OneTouch 9220 USB Color Scanner
Unlock when the scanner is unlocked
Have a Visioneer One Touch 9220 USB scanner and the program says that I need to unlock it but it is unlocked. Do you have any answers?
    Problem Solver:
  • 6 Answers
I had that problem. Based on some info about the Lexmark X85 printer, I began looking for the fiber optic strip. It lies at the bottom and stretches about halfway. It's about two inches wide and hard to see because it is virtually part of the case. I cleaned it several times. Getting the case off was a pain. That didn't quite work but then, just about the time I had given up, I took the scanner off my recycle pile and gave it one more shot. This time, I cleaned the fiber optic strip and then took the carriage apart and found the glass mirror-like thing that glides along the strip. Cleaning that did the trick. It is working again.
Posted on Aug 30, 2010
Lost the software for visioneer onetouch 9220 usb scanner
You can go to visioneer's website and find that driver here: http://support.visioneer.com/products/9220/downloads.asp
For future references, simply take the manufacturer, the model and type download driver at the end of it, and place in Google Search. Then, MAKE SURE the link you follow starts with the manufacturer's website. Best of luck! Hope this helps...
Aug 24, 2014 | Visioneer OneTouch 9220 USB Flatbed...
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
I am unable to scan in Onetouch 9220 after I unlock the button.
Look for the fiber strip along the bottom of the scanner inside the glass. Clean it and the mirror-like thing on the carriage above it. These things work together to encode and decode. Dirt drives them nuts.
May 24, 2010 | Visioneer OneTouch 9220 USB Color Scanner
How to unlock the scanner
Shut down system and let it rest for a while. When restarted, it worked. ???
Mar 31, 2009 | Visioneer OneTouch 9220 Flatbed Scanner
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Scanner says it is lock, but it isn't
I had the same problem. The scanner car is stuck on the travel rail. Disconnect the scanner and remove the top. Turn over and remove 4 screws holding top to bopttom body. Turn right side up and push in very hard on the lower riight side of body to release snap in holding top to bottom. There are four snaps, one at each corner of scanner. Do the two rear snaps next. Then the left front should slip off. Unfold top toward front so as not to pull butoon wires out of track in bottom body. Clean 1/4" rail at rear of scanner and apply small amount of vaseline. Move car by turning gears at left rear to get to all of the rail. Reassemble. Happy scanning.
Jan 15, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Visioneer one touch 8920
The scan motor is straining against somethinmg - so re do the lock/unlock routine and carefully examing the machine and the manual - usually in PDF on the software disk.
Oct 15, 2008 | Visioneer OneTouch 8920 Flatbed Scanner
My scanner does not scan properly
time for a new scanner. these are cheap units and sounds like your lamp is going.
Jan 13, 2008 | Visioneer OneTouch 9220 USB Color Scanner
111 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Jeff Hogancamp
Jeff Hogancamp
Cosma Papouis
Cosma Papouis
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
