Question about Philips GOGEAR SA6045 MP3 Player
The Philips GoGear SA6045 i have won't start or reset. What should i do?
    Genius:
  • 1,456 Answers
The problem your are encountering is often caused as a result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
If this isn't the case then there is an error preventing the player from powering on and this cannot be cleared by resetting
The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Posted on Aug 30, 2010
Testimonial: "thank you you saved my life "
  • Korede Atunrase Sep 02, 2010
    you are welcome sir..
  • chris Garcia Sep 30, 2010
    what if you dont have the disk?
Does wmv format supports philips gogear vibe
Hi
Philips go gear SA6045 mp3 player supports MWV format files. Please click on this link for details---
Hope this helps...
Daniel
Aug 28, 2010 | Philips GOGEAR SA6045 MP3 Player
Turn off
When you have the GoGear SA6045, see page 8 of the controls in this manual:
http://download.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
PDF files can be read with Adobe Reader and saved to a location onto your computer for later use.
When using the OFF function on your player doesn't work, a RESET mostly helps.
When you have another model than the picture shows, reveal your model number in this problem thread.
May 20, 2010 | Philips GOGEAR SA6045 MP3 Player
The gogear sa6045 is not registering on my computer
Get the software from www.usasupport.philips.com
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 07, 2009 | Philips GOGEAR SA6045 MP3 Player
My Philips GoGear SA6045 displays a distorded main menu
xxx
There is a program on the installation CD called the Philips Device Manager - it has a Repair option. If you have lost the CD, you can get the Device Manager from Philips website.
-Tha Mp3 Doctor
xxx
Nov 25, 2008 | Philips GOGEAR SA6045 MP3 Player
GOGEAR SA6045 does't work with Desktop HP Compaq dx 2200 or dx 2300
Download the clean version of the software from Philips website in each computer BEFORE you plug the GoGear into the machine.
Sep 18, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player doesnt register.
I worked on this thing (sa6045) for three hours................no luck.Finally got a fix.....Go to programs add/remove menu under control panel and delete Philips device manager.Then go to Philips site and download new driver:http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&mid=Link_Software&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080506223817_68.47.250.64&ctn=SA6045/37&dct=PAL&did=AEN&file=/files/s/sa6045_37/sa6045_37_dmr_aen.htm
Install your new driver and be SURE windows media player is not running or trying to sync.If it is running in background philips device manager will not work.Once new driver is installed you can pull up the repair panel and do a hard reset thru software on your Sa6045.
Good Luck
May 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
454 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
