Question about Kenmore 24032\24036 Top Load Washer
My kenmore elite washing machine ( TOP LOAD) is not agitating or spinning". is it the belt or the clutch. Modle # 11024952300
  • Kenmore Master
  • 2,328 Answers
There's no belt in the kenmore washers,they have a motor coupling.take out the two screws that hold the top console down.flip up the console it's on hindges,next with a screw driver pop the two metal clips and unplug the lid switch harness that's in between the metal clips,then open the lid and grab the frame,pull the frame to you and up and remove the whole frame.on the bottom you'll see the pump,with a screw driver pop the two metal clips and slide off the pump.take out the two screws and pop the metal clips and slide off the motor.on the back of the motor you'll find the coupling broke,it sounds like alot of work but it takes around 20 minutes to do
Posted on Aug 31, 2010
  • Sal DeAngelo Aug 31, 2010
    the part number is 285753A for the coupling
Kenmore Elite Model 11023032101 will not Spin
if it agitates and pumps out water it is not the lid switch.  you most probably have a bad brake/clutch mechanism.  the fact that it spins tells me the transmission is good
Jul 30, 2010 | Kenmore 23822 Top Load Washer
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The agitator in my kenmore elite washer won't agitate. The water won't spin out. The basket turns, and we've had the clutch replaced. Any suggestions?
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Jan 01, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer has spin problem
Sounds like there is a problem with the clutch , they go out often on whirlpool washers and are not too much money. its located right above the trans. and you must pull everything out of the bottom.
Oct 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer spin problem
its possible you have a bad clutch assy, or perahps something stuck between the outer and ineer tub(i.e. sock) preventing free spin of unit, the clutch is mounted on top of the transmission assy and requires a little bit of work to acess, im sure you can find a video on you tube as to how to acess that
Oct 18, 2008 | Washing Machines
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
253 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
