Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My washing machine it stop when is get to rinse and spin stage
The waters does not go away and it stop to spin and rinse
  • 172 Answers
Hi shehe,
It would help to know the brand and model to give you the beast possible advise. But with the limited information I have I would recommend that you check your pump filter and your drain.
On most front load washing machines they have a filter that you can unscrew and remove from your drain pump. Be ready to catch some water if you take the filter out. If the filter is dirty or clogged just clean it out and get back to washing.
If the filter is clear you may have an obstruction in your drain, clear the drain and the washer should be able to pump out the water again. If both are clear and it is still not pumping out, check voltage to the pump. If you have voltage and its not pumping then you have a bad pump. Good luck and please send more information if you have more questions. Good luck Mike Anderson
Posted on May 08, 2008
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
LG WD12331AD: stops at different stages. Water in Tub. Rinse spin cycle: OK.
Look for a temperature sensor on the motor, usually two wires going into a wrap of varnished paper, with the sensor inside. Run the unit with the sensor away from the motor, but check the motor by safely touching it to see if it is overheating. If the sensor is tripping too early, see about replacing it. It won't be an available part, I expect, but can be found online by Googling the numbers on it.
The motor could also be overheating because some bearing is bad, too, check the unit for freedom.
Nov 26, 2013 | LG WD-12126RD Front Load Washer / Dryer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Hi I have a auarius wma37 extra washing machine, It washes fine but just stops when it gets to rinse and spin. the drum drains to safe and the door will open. if I wait and change program to just rinse and...
Hi confused...It could be that your cold water inlet valve is faulty. Many machines will only rinse with cold water...No cold water...No rinse! Check that the machine actually is filling on the rinse setting. An inlet valve in not a big job....Nomess
Apr 05, 2010 | Washing Machines
Washer does not rinse & spindry after getting submerged in water.
everything needs to be checked from the timer control button to the motor, im guessing it agitated through the wash cycle but wont spin now right? your flood could have damaged any number of items... run through ( with the machine unpluged ) and test the components for continuity and/or resistance.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer doesn't stop
select a hot wash of some kind and check if the water heats. if not, problem could be heater or associated stat
Mar 30, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
