SOURCE: power windows and power doorlocks won't work
Try replacing your window switch on the drivers front door.
SOURCE: headlights quit
Using a multimeter check for voltage across the headlight fuse if yes then follow headlight power wire to the connector under the tank, if power is present then check for power at the headlight plug
It is quite common for wires to split inside the harness where they go around the headstock. This is because of chafing & stretching as they move with the handlebars
Hope this helps
Please mark as helpful if it has been
Ride safe
Bike-doc
