Question about The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System
I have a Singing Machine, Model Number SML 385 and it will no longer display the lyrics on the TV screen. Everything else seems to still be working fine. Any suggestions?
Searching for the lyrics to Time for Singing by Kelly Minter.
Why not just listen to it and write the lyric down? It doesn't seem to be available online anywhere obvious.
Mar 19, 2017 | Music
Tip
Hi Viper, Thanks for the tip. I'm having the same problem with my Xerox...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 14, 2008 | HP PSC 1610 All-In-One InkJet Printer
I have a singing machine, model STVG-1009, and the disk is not spinning and nothing reads on the screen. what could be the problem? how expensive is it to fix?
There appears to be a problem with the printed circuit board on these machines.
A possible fix is to remove the back cover then loosen the 4 screws holding the printed curcuit board.
Jan 28, 2012 | The Singing Machine Audio Players &...
Have new ism Singing machine, bought Billboard karaoke CD+G disc, while playing the CD the lyrics displayed on the machine get scrambled or parts of words seem to stick on the screen and new words are...
I had bought the same one and had the same problem.I had called the singing machine company and was told that billboard and party time is not compatiable. I had returned mine. They had also told me that they came out with a newer model singing machine iSM-1028n. I am having a hard time finding it.
Oct 18, 2010 | Video Game Consoles & Games
Mic doesn't work
Hi Troy,
Have you inserted the mic in the right input? Make sure it is not inserted in the headphones input. Besides that take a look at the display menu and make sure the volume is turned on.
Mar 09, 2010 | The Singing Machine SINGING MACHINE...
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Lyrics option in Archos Player
For as long I've got mine, 605 WIFI 160 GB, I don't have such an option for lyrics.
On the PC you can add lyrics in the summary of the music file, but not all
the options from summary appear.
But you mean that you can see the sentence which they are singing at that moment every time?
I don't think that is possible, but try to contact, who knows they can create it soon,
if they change that and add it in new firmware!
Oct 25, 2008 | Archos 605 WiFi Digital Media Player
Kareokee singing machine SVt 700
The mikes are easy. Generally the wire gets disconnected - so you can either buy a new wire connector or have it soldered - very easy job. Not sure about the screen display problem - good luck
NJ
Jun 30, 2008 | The Singing Machine Singing Machine SME399...
The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System Logo
26 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
paul
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
