Question about Canon SELPHY ES1 Thermal Photo Printer
SELPHY printing too dark
Photos look fine in iPhoto but when I print to the ES1, they come out too dark.  And they print fine on another printer.  Can anyone help?
  • 3 more comments
  • Damy May 11, 2008
    The only work around I found unitl now, is editing the picture and make them more bright. But, what a shame that you have to edit a picture which doesn't need editing. So any other suggestions are welcome..
  • Neilabc Jun 28, 2008
    Hi - I have the same problem. Have tried adjusting the brightness and Contract on the printer settings , but didn't make any difference.
  • mfkap Nov 09, 2008
    Same problem here, have to make the pictures look too bright just so they print decently
  • Anonymous Nov 27, 2008
    Same problem with mine. Prints come out too dark.
  • hitomiie Jan 26, 2009
    same problem, really frustating
I have some experience with color profiles, after trying to fix this problem by changing the profiles in Photoshop, letting the printer manage color, leting PS to do so, and every possible thing.... I found that increasing brightness, and 2 points of saturation on the printer dialog pretty much prints what you see on the iPhoto screen. I have the Selphy 740 not the ES1, but might be the same....  SELPHY printing too dark - abee9c5.gif
Posted on Jan 29, 2009
I use iphoto and am working on a newer generation iMac. Here are the settings that are giving me the best results:
Saturation -1 Brightness +3 Contrast -2
Hue: R 0 G 0 or -1 B -1 or -2
Every monitor is different and even the lighting that you view your monitor in can influence the perceived color, but these settings have made me decide to keep the Selphy and not return it and spend more on a different option. If these settings don't work for you, sacrifice a pack of paper and play with these color setting til you find what works. I had to futz a lot before I found these settings that work for me and I'm a graphic designer who deals in color issues every day.
One suggestion -- as you try different settings, take notes and jot down the setting on the edge of the print so that, as you try 4 or 5 different variations, you'll be able to visually remember what works and what doesn't. Good luck!
Posted on Dec 05, 2009
    New Friend:
If printing sttaight from camera try knocking off my colours on the printer settings or from pc, preferences lighten the brightnes tab one click. If printing from Elements Levels midtone marker to about 27.
full photoshop change the 80% &20% down 10% in the Transfer menu it will need a test. Also make sure the printer profile is on LAB .
Posted on Apr 26, 2017
You are right Akabrooke- have the same problem of photos too dark. but photos have far better balance of light and dark if printed straight from SD card rather than through my mac. Annoying though as got it for xmas and was hoping to print out a whole back log of photos on from my mac. Now will have to just make sure that in the future I print straight from SD card.
Posted on Dec 30, 2009
Hi! I do not use ES1 but I own a selphy CP-780. For the longest time, I've been trying to tweak the brightness, contrast and saturation settings to make the prints appear as they do on iphoto. They do help a little but it never looks like it does on iphoto. However, when the prints always turn out perfect when I print directly from the SD card. Hope that helps!
Posted on Jul 13, 2009
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
I have tried to download the driver for my Canon Selphy ES1 photo printer but nothing happens afterward the download finishes. I've lost the disc so can't use it!
You can download the drivers and manuals for your printer at the official Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=14226
Generally, you need to disconnect your printer before you install the driver, plug in the printer after installation. Things should work fine from there.
Let me know if you need additional help. Thanks.
Nov 12, 2009 | Canon SELPHY ES1 Thermal Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
Can I print photos from a CD to the Canon Selphy
Yes you can. When looking at the photos on the CD, right click the photo(s) and choose the print option. The computer doesn't care where the pictures come from!
If you feel this solution helped, please rate me as it helps me out,too.
Jan 17, 2009 | Canon SELPHY DS810 InkJet Photo Printer
When i try to print on my Canon SELPHY ES1 i get a message saying "Cartridge has changed" and it won't print. Can you help?
Check "Printer Properties" so that the cartridge is set to color if E-Pxx cardridge is mounted and set to B/W if E-PxxBW cardridge is mounted...(xx stands for number of postcards) // Kjell.sundling@hotmail.com
Aug 30, 2008 | Office Equipment & Supplies
Cannot print from my PC
totally unload the driver and software. Then go to printer/faxes - install new printer and when the new hardware prompt comes up - ignore the CD prompt and select from list instead. select Canon select Model- then try come back with the result.
Sep 18, 2007 | Canon SELPHY ES1 Thermal Photo Printer
Canon SELPHY  ES1 Thermal Photo Printer Logo
2,936 people viewed this question
old marine
old marine
