Question about DeLonghi RO2058 Toaster Oven with Convection Cooking
Door handle came loose. The head of the screw is covered.
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
Replace door handle
Not enough info to help you. However, if the door can be separated into two pieces fitted together, you will see the screws holding the handle.
Otherwise, you have not asked a question.
Oct 20, 2013 | Calphalon HE650CO XL 1400 Watts Toaster...
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
Handle fell off. cant get to screws
There must be a way to attach the handle. My suggestion is to call the service center for that item and have them tell you how to reattach the handles which should not have come off in the first place.
Aug 10, 2012 | Toaster Ovens
Unusual screw head
take picture of it w/ phone or camera or anything u have thats digital. Take to lowes, or depot, or somewhere possibly that sells tools and ask sales person.
Aug 02, 2012 | Toaster Ovens
Need to tighten screws holding handle. How do I do this?
We were able to tighten them down. We:
unscrewed the handle entirely;
removed the little black rubber/plastic screw covers (you won't be able to use these with this fix);
held the handle stationary in one hand;
used needle-nosed pliers to turn the screw into the handle;
then switched out the pliers for some small tweezers as the handle got close to the dooor, and turned the screw with the tweezers.
Note that the left-hand side of the handle is reverse threaded. So, you will turn the screw clockwise to screw in on the left; and counter-clockwise to screw in on the right.
Aug 03, 2011 | DeLonghi RO2058 Toaster Oven with...
How do we change the heating element. It was hit and broke but not in half so we need to remove it and add a new one.
I ordered bulbs online at http://www.smallappliance.com/ They come in a set of 6, you can't order less than that, I looked all over the place. Here is the part number: Krups SS-185303 Heating Element. You might want to find them on Amazon.com because by the time you order them from the above website, with shipping, it will come to more than you will pay total on Amazon and it's coming from the same place. Just in case Amazon doesn't have them in stock (you never know) I wanted to give you the source for the bulbs.
  1. Unplug unit and remove all trays and racks and crumb tray. (I took this time to do some much needed deep cleaning too.)
  2. First you have to remove the old bulb. I tried it the hard way by trying to pull it out - it's connected with screws on the left and right to the connector wires.
  3. I placed the oven on a big light colored towel and had a cup ready to place all my screws in. I also took pictures of it before I started taking it apart so I had something to reference when putting back together. I used a small sharp phillips head screw driver, DW40, household oil, a set of leather household gloves and patience.
  4. I first removed the cover of the whole oven by starting with the bottom legs (there's a screw under the rubber foot), the bottom, back and then removed screws on the face/door. Becareful of the door hinge. You might want to use some household oil or DW40 before you start to attempt this. My oven is 6 years old and we've used it everyday. There was some accumulated stuff around the screws.
  5. Carefully remove cover of oven and door/face. There's going to be a thick wire that will connect the interface circuit board to the internal boards so again, becareful when removing the face of the oven. The glass door may pop out of the hinge so, again, becareful.
  6. Make sure and observe how the door hinge and spring are placed and take a picture as you're going to have to put it back together.
  7. When I got to the connector of the bulbs I had to use, very carefully, some more household oil on the screw.l I held the ceramic socket with my leather utility gloves on and gently applied pressure to get the screw loose on both sides.
  8. Carefully place new bulb in hole/holders and gently screw the wires back on, start with the right side (facing the oven).
  9. Reassemble the door hinge if you took it off. and place the face on just for position.
  10. Attach the outer cover, back first and then bottom.
  11. Attach face and make sure hinge is working properly and you've tucked that wire back in.
  12. Attach legs.
  13. Remove anything else plugged into socket you use for the oven (just in case it blows the socket which has happened with some DIY repair in our house). Plug in oven and test it out.
  14. I hope this has helped you. If not, find some coupons for Bed Bath and Beyond and purchase a new one and sell your extra bulbs on ebay or craigslist. Good luck!
Jul 10, 2011 | Krups FBC2 1600 Watts Toaster Oven with...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Kenmore toaster oven handle fell off
try magic putty. it works on everything
Jul 11, 2008 | Toaster Ovens
DeLonghi RO2058 Toaster Oven with Convection Cooking Logo
91 people viewed this question
Top DeLonghi Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Craig Butler
Craig Butler
Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
