Question about Kenmore Dryers
Have a Kenmore 70 series. It"s squeaking while running. Lubricant? Bearing?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Kenmore 70 series dryer squeaked, heated, drum turned, then turned off and won't come back on--is it toast or worth fixing?
It all depends on how you look at things.
Comparatively speaking, dryers are a piece of cake.
However, with out mechanical ability and tools, it could be over your head.
You decide.
If you choose to fix it yourself, it could be done for a few dozen dollars.
Hiring a repair man could make it cheaper to buy a new one.
New parts are available through "Sears parts" on the internet.
Someone will need to take it all apart to see why it stopped on you. To do it yourself, you may also need an electrical testing meter.
Be blessed.
Mar 20, 2013 | Kenmore Dryers
NordicTrack treadmill squeaks when walking but fine when running.
1) lube the deck belt, and possible the deck is worn must be replace
2) lube the rollers bearing too.
3) test the bearing motor, need replace too.
God bless you
Jun 17, 2012 | Exercise & Fitness
I have a Kenmore 70 Series dryer that squeaks when it runs, do I have to oil some thing?
A lot of the Kenmores start squeaking if the main bearing is starting to wear out and then it starts to rub against the frame.
Jan 18, 2012 | Dryers
Kenmore 70 Series dryer squeaks while tumbling - otherwise it works - what might be causing the squeak - a belt or loose screw?
heatman101
Dec 16, 2010 | Kenmore 64722 Electric Dryer
Kemore 70 series make a load Squeaking noise when on spin.
I would guess it is a belt issue. You may have a worn drive belt that is making all the noise.
Dec 16, 2009 | Kenmore 24712 Top Load Washer
Kenmore 70 series
hello mam for two years you have not used the washer so the bearings may worned out so lubricate the bearings and check the belt should not have any cracks on it,and after lubricating run the machine without loading clothes the observe the noise if seems to be same then change the bearing to change the bearing call the engineer.
Sep 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
