Question about Samsung Home Security
Yes i have a ssc14web observation system and we lost power for a few minutes but when it came back on the system would not show all 8 cameras i unhooked all 8 of them and hooked them up one at a time but when i hook up the 8th camera the system goes blank and flashed back and forth between quads and does not show any cameras
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: yes i have a ssc14web
I see, if you hook that 8th camera to a different location on the device, does it do the same? It may be a problem with that camera that occurred when power was lost, that is what it sounds like. Test it by plugging it in 7th for example...
Tim
Posted on Sep 29, 2010
Bunker Hill security 8-Channel Surveillance DVR item#61229 keeps rebooting itself. "system initializing"
Rotorway Bunker Hill never lasts and it's the cheapest one with the worst resolution you just don't want to operate and put your life on the line with this unit
Jan 18, 2016 | Home Security
How do I pair up cameras when 4 out of 8 go out
NEED TO CHECK THE POWER SUPPLY THAT FEEDS THOSE FOUR CAMMERA'S
Nov 12, 2014 | Lorex Sg19ld804161 19 Inch Lcd Observation...
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 08, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
How do I reboot or reset my clover 8 camera DVR combo? Model # COM2208C?
Disconnect the power for about 5 minutes; the wait is to let the internals discharge (5 is minimum, a little longer if you want to), then plug it back in. That will reinitialize the system.
May 29, 2014 | Clover Corporation Clover Electronics...
Motorola mini defy wont load only motorola shows
How to hard reset:
Warning! All data will be lost!
1.Power off your phone
2.Press together volume up + volume down + power button until recovery menu appears
3.Select "recovery" with volume buttons and press camera button to confirm
4.Press home button when Android logo appears
5.Select "wipe data" with volume buttons and press camera button to confirm
6.Select "yes" and press camera button to confirm
7.Wait until format ends
8.Select "reboot" and press camera button to confirm
9.Wait until phone restarts
That's it!
- See more at: http://factory-reset.blogspot.com/2013/09/motorola-defy-mini-xt321-hard-reset.html#sthash.eUfAgbLd.dpuf
Jan 31, 2014 | Motorola Mobility Defy Mini XT320 Black...
RESET A PASSWORD ON A CLOVER SECURITY SYSYTEM
remove motherboard battery 5 minutes ... reinstall ... causes checksum reset ... default passcode for most is 11111111 eight ones ... done ... enjoy!
Oct 02, 2013 | Clover Corporation Clover 17" CCTV...
Lost Sky connection,to a Toshiba TV.co.nz
Hello!
Try to reset your TV. Unplug it from the power strip, then plug it back in within a minute. It might help. Make sure, you Sky is on, before you plug TV back into power. Of course, connection between 2 units must be intact.
Modern TV sets will scan inputs at "start up" and will show you available signal sources. Be patient: it might take a few minutes for systems to recognize each others settings. Also: after you done with that, remove a battery from your TV remote. that will prevent your next mishap.
Good luck,
Alex.
Dec 10, 2011 | Toshiba Televison & Video
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
Can't get the quad screen to let all four I need a manual
I believe the newer version of your unit is the SSC14WEB. The instructions should be similar.
You can download the manual at:
http://dl.owneriq.net/3/369f279c-f502-4903-8918-0912f9063e94.pdf
Dec 18, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Problems with extended battery
Try to check your phone if the battery connector having lost to contact the battery well. Or the problem came from your battery try to borrow from your friends battery to identify the problem.
Please rate me solved if you like my problem.
Best regards,
Philip
Nov 01, 2007 | Dell Axim X50v Pocket PC
Home Security Logo
57 people viewed this question
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
