Question about Mantis Garden
Tiller wont start, I changed the gas in the tank with new gas that I mixed the little bottle of 2cycle oil as required, changed spark plug, . I called the factory or manufacturer last week, they said pull the wire loosefrom engine that goes to off and on switch, the ground wire is a thin wire, disconnect that and try to start, if it starts then the switch is not working. the connectors I have are a small cannon plug device no smal wire is evident unless I peel the coating back, I am not going to do that, this till er was purchased in 2004, I had in the plant for overhaul in 2008 , when I got it back it ran very good but up till last time in early spring it didnt run so good like it would almost bog down then run at high speed after a lengthy warmup, but now it wont even sputter when trying to get started,,,,,,,,,,,,Dennis in Arizona
  • 5 more comments
  • guifiddle Aug 31, 2010
    Dear Sir, I had a troy bilt for twenty years till I moved. where I moved to had a small area for a garden that is why I have this Mantis I sold the troybilt because it was too big for the job needed, thankyou Dnnis in Az
    A troy built or large tiller is too big for the garden I have or its use, that is why I have mantis but unfortunately it doesnt always work. there arent any garden centers here or places to purchase the small carburetor you mentioned, and besides if there were I dont have the tools to perform this function
    there are several small repair sights here but the last time i had a repair done on this tiller it worked one time and then quit working (No guarentee) from the repair sight
    Helllo: I dont have a meter nor do I know how to read it, this tiller is a Mantis tiller I think it is the same engine as a Wankel type , no piston just what a wankel performs, no fuel pump or carburetor, the electrical system I think is a Magneto device, no way to check it
  • guifiddle Sep 01, 2010
    The filter has been changed, and this engine doesnt have a fuel bowl, or a carburetor that is noticeable, this is a rotary engine is a two cycle device runs on oil and gas mixture
    Mabey I didnt enter what type tiller it is, it is a Mantis a 2 cycle engine, the engine doesnt hve a piston but I think it is a rotary engine, has very small parts and I think the electrical system is a magnito , cant be sure
    this engine doesnt have an oil switch to cut off if you dont change it. the only oil is in mixed with the fuel
  • 3,247 Answers
Looks like the carburettor is not taking the right amount of air / gas mix.
Have you tried to set the screws on the carburettor to tune the air mix?
The other part could be the high tension cable feeding the spark. Have you tried to test if the spark is generated by the spark plug?
Posted on Sep 01, 2010
  • 580 Answers
Have you cleaned the air filter? If not, do so! Also remove the spark wire & clean the connection tip to the spark as well as the spark plug tip. They sometimes get an oxide &/or rust causing a poor connection. Make sure there is no water or dirt in the float bowl of the carb. Good luck! Hope this helps you.
Posted on Aug 31, 2010
  • 2,272 Answers
I agree that spark plugs replaced.But did you checked with meter for voltage at spark plugs.Also do the spark plugs getting any power.Check it with meter and confirm. The other thing to check is the fuel pump is the fuel passing from the pump and reaching the engine.Get it checked . Keep updated.Thanks.
  • 15,935 Answers
Sounds like a fuel delivery or carb problem.... but you MUST be sure the switch is operating properly.
If you're not willing to do it - take it to a professional.
THanks!!
  • 17,130 Answers
Possible that there is an oil switch that cut off if the oil was not changed on time( as it gets thicker and pressure drops) This pressure switch will cut off spark and the engine will not start. So check this out.
If not try to see the spark after removing the plugs and cranking.If there is no spark you will need to start from the source, check the coil voltage if the momentary impulse comes for switching if not check the contacts/capacitor.
Once the plugs are sparking , pump up the engine to dispel all the excess fuel in the cylinder, wait for some time before the plug is put inot. Now heat up the plug in your gas burner a bit to clean all smears and set in with the heat.
Now crank and see if this starts.
  • Donald DCruz
    Donald DCruz Sep 01, 2010
    Whatever be the power , check the magneto to deliver the spark for the plug. Though this is a rotary engine the compression and the firing should be intact. The suction cycle must draw forward the fuel intake. So if you have cranked always make sure the excess over flow is out of the engine. Also heat up the spark plug and put in the crank. hope this works.
  • 3,083 Answers
There's a lot of comments about this problem on this web blog:
http://forums2.gardenweb.com/forums/load/tools/msg0514221722676.html
I'm inclined to think you should try some carb cleaner first, just for kicks. Also, the diaphragms might be bad, and a carb rebuild might be in order.
Good luck, hope this helps, and thanks for using FixYa.
  • 10,865 Answers
Hi Dennis. Take your tiller into a local small engine repair shop. Other wise you are going to be getting trial and error suggestions and spending money unnecessarily. J.
  • 10,319 Answers
Most garden equipment has problems such as yours for they are not used every weekend, and put away for the winter. The most common problem is when stored away and the particles that collect in the fuel tank break loose when sitting for months. Then when you bring it out and try to start it these particles flow through into the jet tube and clog up one or two drilled out holes starving the engine for gas. I see you have a two cycle engine. That is not good for a tiller. get it fixed and buy one with a 4 cycle engine instead. It does the job 4 times as fast and gives less trouble too for years. Mine is ten years oud and never had it apart yet. Of course its a Troy Built
Posted on Aug 30, 2010
  • frank thomas wilson
    frank thomas wilson Aug 31, 2010
    The tiny carburetor can be purchased separately at most garden centers. These are not advise by most experts to rebuild. By the way 2 cycle engines are not worth having on any garden equipment for the just do not last. A 4 cycle engine can be had on a small triller and they drive themselves as well where as a 2 cycle engine you have to push it along. If yours had a drive option that wears the engine down the first few hours of work on them if its a chain drive system
I have a B&S weed trimmer Model 21032. I wish to put in some gas stabilizer but I don't know the fuel tank capacity. Any idea?
The easiest way is to mix it in your gas can as you buy gas at the service station.
If it's a 2cycle, most of the oil mix I buy says on it that stabilizer is included in the oil mix. Fuel stabilizer does not take the place of your 2cycle oil mix. I haven't ever had problems with my 2cycle gas going bad even when left for awhile.
If it's a 4cycle you can mix the stabilizer in when you buy gas.
For now, guess at the fuel tank size ( a quart ? ) and work out the ratio to add to the trimmer tank. A teaspoon maybe. A little too much won't kill anything.
Sep 27, 2017 | Garden
Do i mix the gas with 2 cycle oil
yes, read on machine or manual like 50:1 . usually a small bottle or packet of 2cycle to 1 Gal of gas, mix in gas can not tank.
Nov 14, 2011 | Garden
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Battert is good spark plug is good I forgot to mix 2cycle oil in gas could that be the problem has plenty of oil when I try to kickstart it it acts like it wants to start but wont it has power just wont...
Does it have strong compression? If not, running it on straight gas could have done its damage. If the compression is strong, use a spray bottle to spray some fuel/oil mix directly into the throat of the carburetor. If it fires after using the spray, it means you're not getting fuel to the engine; make sure fuel is flowing from the tank. If it is, check your carburetor for gumming, clogs or stuck float.
Jun 26, 2011 | Cycling
What is the mix for gas and oil in a ryobi tiller, model # ry60511a, 25cc
To make your day a little bit easier, you can buy the one gallon mix bottles of oil from Lowes, Home Depot and Walmart. Just goto the lawn and garden department and there you will find these bottles of oil. One bottle to one gallon of gas.
May 03, 2011 | Ryobi Cultivator
Engine wont start. Changed plug; mixed new gas/oil combination. No start!
if you have a spark at the plug try cleaning the air filter, could be just dirty
Jan 07, 2011 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Motor overheats and seizes.
what is your proper mixture?50:1?
Be sure you are mixing 2cycle oil to 1 gallon of fuel or whatever it takes to make this ratio
My reccomendations are run 40;1 3.2 OZ OF OIL TO ONE GALLON OF GAS
also you may have a lean out condition and the H on the carb, may need to be ritchened a little
Motor should not be screaming you should have a slight blubber when throttle is held wide open
May 25, 2009 | Mantis 2-Cycle Tiller
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
98 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
