Question about Peg Perego John Deere Gator HPX Ride on Toy
Does not seem to be getting the connection from the gas peddle goes only for 2 seconds and than wont run? Also look like only one back tire is moving? Also need something to make it grip the ground more? Any ideas in these problems? New to the john deer gator!
    President:
  • 670 Answers
Often the switches on this toy goes bad. One way to check is to put the back of the jeep on something like a cinderblock so that the back wheels can rotate freely in the air. Press on the gas peddle with your hand and see if both the back wheels turn. Change speeds and see if both work change also. If both back wheels do no move, the problem is either with the wiring or the motors. A good source of parts is mypegperegoparts.com. They were very helpful to me for my problems with little ones jeep. Hope this helps you.
Posted on Aug 30, 2010
2001Mercedes E320. Drives fine until I take my foot off gas peddle the car is still running but gas peddle does not work turn off then on runs fine until I take my foot off the peddle what is happing
If you have drive by wire. I would check the TPS first. It's under the gas pedal. (bad location). Unplug it and plug it back it. (bad connection) see if it still does it. If so. Have the codes read. I replace a lot of these because of the location. Bad water and moisture source.
Jun 21, 2015 | Cars & Trucks
Tip
Alignment of Throttle Body
put the key and put it into the position just before the starter turns (do not start the car) push the gas peddle all the way wait 3 seconds and turn the key all the way back but do not take it out, now release the gas peddle and wait 2 minutes! remove key than put it back in and start the car! you should notice a better response while pressing the gas do this once every few weeks!
on May 19, 2008 | 2002 Audi A4
Car fires runs a few seconds then dies.
will it keep running when you use the gas peddle and wont idle or it cuts right out
Jan 15, 2011 | 1994 Chevrolet Cavalier
I have a 2000 Dodge Durango and after bleeding the brakes (after doing some brake work) we can't seem to get the peddle to stay hard. When taking it out for a drive the first time you press on the...
Bleed them again, and don't leave the bleeder open, every time the person lets up on the pedal. close on the way down and open and close next time etc. Your letting air back into the system. Don't let the master run dry.
Sep 19, 2010 | Dodge Durango Cars & Trucks
Fuel line
Is the security light flashing when it dies?
Jul 18, 2010 | 1996 Pontiac Grand Am
96 Jeep Grand Cherokee wont go into reverse
chheck your tranny fluid. if it's ok, probably need tranny work done.
Jan 10, 2009 | 1996 Jeep Grand Cherokee
1999 GMC Suburban 2500. 454 engine
sounds like fuel pump pressure. I had the same thing happen to me in a Lincoln mark VII and the electrical connection was shorting out in the fuel pump. I changed the fuel pump..Returned under warranty) put the new one on with filter and had no problem with it.
Sep 09, 2008 | 1999 GMC Suburban
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
