Question about Canon ImageRunner 3245 Black and White Copier
It doesn't seem to know it has paper I send a print job it comes up on the system monitor as an error It asks me to load the paper then I have to hit okay on the screen to release the print job.Any ideas what the problem is? thanks
  • 1,219 Answers
to be sure first check the paper size on cassette.Must match the paper size in cssette.Then under printer driver properties, check/set paper size matching one in the drawer.
Depending the program from wich you want to print also check when the printer dialoge is opened that you set correct sett. , like wich tray, wich paper size,...
Hope that helps!
Posted on Aug 31, 2010
Hull, my canon IR 2520 cant print when i send the job it only beeps with a red light, can some one help me...
press the status monitor on touch screen. it will show that load paper LTR. that was an error.
go to additional function-> printer settings-> paper size over ride-> make it ON.
Sep 22, 2015 | Canon Office Equipment & Supplies
Bizhub 43 asking for paper
does that include the by pass tray??? being filled some one is sending a print job that uses the bypass tray
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 05, 2014 | Konica Minolta Office Equipment & Supplies
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
Oct 27, 2009 | Dell 3010cn Laser Printer
Load Paper indicator problem - Canon LBP5000
You should have a cancel button on the printer press that and hit cancel job. if that does not fix it unplug the printer for a few min and it will clear. make sure when you send an envelope to one of these you select the right paper type and "manual feed" in your printer options so you do not cause this again.
Jun 22, 2009 | Office Equipment & Supplies
When I send a 2 page 11 x 17 job to the printer. It prints the first page and then comes up with an error light that asks for >> Load ppr, Bypass or Form Feed 11 x 8 1/2 Plain Recycled  << When I...
THE PRINTER AND THE COMPUTER NEED TO MATCH THE PAPER SETTINGS CHANGE THE SETTINGS ON THE PRINTER AND TYPE..WHEN PRINTING YOUSE THE SAME SETTINGS AS YOUR PRINTING
Jun 22, 2017 | Ricoh Aficio AP610N Laser Printer
Hi there!!!! my canon mf4140 keeps flashing error ... load correct paper and I have! it prints the same over and keeps flashing
Clear the print job on the computer,and clesr the print job on your copier.
You clear the print job by pressing the monitor button(the one with the diamont shape and eye)select printing jobs and and clear it by selecting the left arrow(yes)
Print the specific job again but first make sure the paper size settings on the file you print is correct.
You can check your papersize settings for the copier in the printer propperties aswell.
Jan 09, 2009 | Office Equipment & Supplies
C5280
when you hit 'PRINT' the window that opens up to complete the job will have a button called 'preferences'. Check to see that the paper selected isn't photo paper. You will have you choice of paper type thickness and size.
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Canon ImageRunner 3245 Black and White Copier Logo
167 people viewed this question
old marine
old marine
