SOURCE: Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
SOURCE: connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
SOURCE: hi,
Not sure what OS you are using, but here is an article with some ideas on how to fix sound recording problems in Windows Vista.
http://www.pcauthorities.com/multimedia/how-to-fix-sound-recording-problems-in-vista
SOURCE: microphone does not work--how do you get it to work
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Click OK and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
SOURCE: HI,I have a VMX1000USB mixer
The XLR are intended for mic and as such they have the gain needed to use mics.
The connectors on the back are LINE LEVEL connectors. To use a mic with these, you will need to have mic preamps to send adequate levels into the jacks on the back of the unit.
Testimonial: "Thanks for the feedback."
