Question about Whirlpool Calypso GVW9959K Top Load Washer
Waher shows c1 what is my problem - Whirlpool Calypso GVW9959K Top Load Washer
  • 2,272 Answers
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
If that does not help then, "C1 = Average current limit Or Instantaneous current limit."
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps at the motor windings
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
How we repair LG ac showing C1
try switch the unit off till ice melts and try running the unit again after. if the ice is till coming back check the filters are clean and outside coil clean. sounds like a restriction in piping,possibly a blockage.
c1 err caused by the indoor pipe sensor being out of spec, possibly due to the ice buildup.
Apr 24, 2016 | LG Heating & Cooling
What is a code c1 on a samsung mini split?
Error code = C1 or CH1
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
Nokia c1-01 power on after few second display on show battary empty than power off
Try pulling the battery out and putting the battery in the freezer for 24hrs. Has worked for me before.
May 07, 2014 | Nokia C101 Cell Phone
Leaks out of the bottom took it a part it appears the water solenoid is bad very rusty and show signs of leaking. Part number is SH-V0329BC-R(C1) or it could be SH-V0829BC-R(C1)
It is SH-V0829BC-R(C1). The valve has leaked internally and prob shorted out. The needle valve didn't close completly when the water pump was running allowing water to enter the valve. Solenoid needs replaced. Krurig used this same item. can get the part on Ebay or do a web search and find a supplier.
Jun 08, 2011 | Breville BKC600XL Coffee Maker
I have a "cl"or "c1"
C 1 means indoor thermostat sensor defective.
Dec 11, 2010 | LG LA185HV Split System Air Conditioner
Hi! lg 18 artcool show on indicator panel the fault " c1 " not 'ch1' , it is air sensor ?
C1-Indoor unit return air sensor fault, Open or Short. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace
Dec 11, 2010 | Heating & Cooling
Art Cool Model Deluxe Type 1 screen shows C1
Your return air sensor is not connected or faulty.
Jul 02, 2009 | LG Heating & Cooling
I want to add two value of two field and display another field in form of ms access 2003
set field number 3 = to sum of first 2
example
A1 = 5
B1 = 6
C1 = A1+B1 which will make C1 show 11
type in C1 = then move cursor (arrow key) over to A1 then type + then move cursor to B1 then hit enter - formula showing in C1 on top should show
=A1+B1 and valud in cell should show 11
Jan 23, 2009 | Computers & Internet
Whirlpool Calypso GVW9959K Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
