Question about Dishwashers
G E Quiet Power 1, has no power to controls, seems to be dead. Checked power cord and it is ok. What could be wrong?
  • 2 more comments
  • chasmillsap Aug 30, 2010
    All connections are secure
    Thanks, I will try that
    This unit has been sitting for several weeks and has not been used. Do you think that water could really be the issue? Or, has the board just pooped out. What is the typical range in cost for a new board?
    It was what I expected
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with its control panel going bad and should be replaced. However, before replacing the panel you can take out the screws and try to blow some air with the help of hair dryer so that if there is any moisture it blows it off. Please do accept the solution if the issue is resolved or post a comment with the complete model no# for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
  • Rylee Smith
    Rylee Smith Aug 30, 2010
    OK, Please do accept the solution if the issue is resolved or post a comment with the complete model no# for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    You are right then I dont think water is the real issue, the cost involved in replacing the control is around $150-$180 for the parts and add some more if you get this done by a professional.
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
My dryer is dead. I have ohmed out the cord and changed the dryer control board (8546219). Still dead, nothing at all. Any other ideas? I have checked the fuse and it is good. I had a local repair man look...
hello again,
no thier doesn't seem to big issue with with reconditioned control panels in fact i dare say yours is good since the dryer didnt start with the original one and still wont start with the one you have replaced. having checked teh thermal fuse to be good and with basically 2 control boards yet the dryer doesnt run it seems very possible the motor is going to be the problem...not sure what led ya to the control board yet it the drum doesnt turn the very part that turns it when power is applied to,if it has powewr to it and doesnt turn the drum it would seem to me its bad....dont get me wrong on this but its like having a broken leg and going to the doctor and saying i believe that my heart is weak since my legs hurts and totally disregarding the broken leg
GENE
Oct 04, 2011 | Kenmore Elite HE4 Electric Dryer
The dishwasher will not turn on. I've already checked my breaker box, and nothing seems to be wrong there with the dishwasher. It worked a few days ago, but now all of a suddden seems to have died.
I would first take a look inside the junction box were the power cord connects to the dishwasher. The junction box is located at the bottom of the dishwasher and can be access by removed the toe plate.
I have seen were one of the wire nuts that connect the power cord will come loose or burn off.
If the power cord is connected ok then I would check the thermo fuse with a ohm meter to see if it's blown.
Aug 03, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
My Power Edge is not starting. On the power supply there are no LEDs whatsoever lit. The cord is OK TO the supply since I have tried it. The server is stone dead and does not start. What is wrong?
In most cases like this, if there are no lights on the back of the power supplies, (i assume there are 2, as I have a 2950 and it has 2) that they are dead, and need to be replaced. If you haven't tried it already try this: 1. Swap out power cords, try different ones. 2. Swap out surge protector if you are using one. 3. Switch wall outlets that the surge protector or power cord is plugged into. If none of that helps then you can safely assume the power supplies are dead. Did you have any power outage or surges lately that you know of?
Jul 01, 2011 | Dell POWEREDGE 2900 Server
Won't turn on. dead. Neither remote control og tv power button will turn on the tv. Power cord OK
The tv power supply board it is dead,that the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a referbish power supply board for the replacement.
Mar 06, 2011 | Televison & Video
I have a GE Quiet Power 3 that has completly died. I cannot get a light to come on or anything to beep when pressing buttons. I checked the circuit breaker and outlet and they are both working fine. I...
A dead set simply means a cut off of power supply. Open the back cover of your dishwasher . Locate the area where the AC cord is located and look for the plastic fuse holder which is usually installed in one of the AC cord line open it and replace the fuse inside with the same amperage or value.
Nov 22, 2010 | Dishwashers
I CAN'T SEEM TO GET ANYTHING ON MY COMPUTER OTHER THAN A BLANK S
Possibilities:
* broken connector where the power-cord connects to the computer
* dead CPU
* dead motherboard
My recommendation is that you take it (with both power-cords) to a local computer-store, and get it professionally checked-out.
Jul 16, 2010 | HP Compaq Presario V2000 Notebook
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Machine will not power up
power out let ok ?
fuse on the power cord ok ?
if all ok then it could be the internal fuse in the power supply unit
dont try and replace it you need a new 1
Mar 24, 2008 | E-Machines eMachines T3830 PC Desktop
Epson lq 1150
chek the power cord is it working fine otherwise show it service personnel may be the mother board of printer is faulty.
bye
Nov 18, 2007 | Office Equipment & Supplies
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
