Question about Wabash Valley Farms Whirley Pop Popcorn Maker
Will the Wabash Whirley Pop work on an induction cooktop?
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Diva DDP-50 induction cooktop the 2 left burners stopt working. How can I fix this.
induction cookers work by magnetic fields so they are a coil of copper wire and a driver circuit it sounds to me the driver board has a problem but you would need to test the induction coils first.
Jan 20, 2014 | Cooktops
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
Aug 07, 2012 | Electrolux 30" Electric Hybrid...
Unlock ilve induction cooktop
how to unlock ilve induction cooktop
Mar 24, 2012 | General Cooktops
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Whirley crank spins without spinning the popcorn bars in the pot
The plastic gear could be cracked. That's what happened to ours. Contact the company and they will send you a new lid.
Dec 10, 2007 | Wabash Valley Farms Whirley Pop Popcorn...
Wabash Valley Farms Whirley Pop Popcorn Maker Logo
232 people viewed this question
Top Wabash Valley Farms Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Wabash Valley Farms Kitchen Appliances - Other Expert? Answer questions, earn points and help others
