Question about Amana 24 in. ADB3500AW Built-in Dishwasher
Grinding Noise I think someone dropped some pistachio nut shells in the dishwasher. How do I clean them out. It's making a terrible grinding noise.
  • menana2007 May 24, 2009
    I have the same problem. I think there may be a piece of glass caught. How do I get to the food grinder to check and clean it out?
  • 22 Answers
Wash out the drain and filter.
Posted on May 09, 2008
My dishwasher is making a grinding sound
It is so common that the machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor / pump/sprayer arm must be checked and inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the shaft and fittings must be checked. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts can solve most issues.
Finally clean the machine ,check for tips on this link:
Jul 21, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
My Samsung dishwasher model # DMR77LHS makes this terrible grinding noise when it is initially turned on & then 2-3 more times through the cleaning process.
Mine make a grinding noise also when the wash cycle starts. I had a repair guy over fixing my fridge and he said it was the washer motor. My machine has only been in use for 1-2 yrs. Other owners say that the tabs on the top rack break off and get lodged in the machine. hope this helps a little.
Dec 26, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
On certain cycles, the motor makes a very loud humming noise.
quite possible that noise is from foriegn debris( ie.chicken bone of pistachio shell, toothpicks) getting into macerator/chopper assy, wouldnt panic just yet, give it a fewloads to try to clear itself, a few screws leading down through the top of motor assy (under lower spray arm should give you access to assy if needed
Feb 22, 2008 | Amana 24 in. DWA22A Built-in Dishwasher
Amana 24 in. ADB3500AW Built-in Dishwasher Logo
660 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
