Question about Timex T5G341 Sports Radio Control Watch
I accidentally turned off the transmitter to receive the time updates; How do I turn it back on?
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
12 hours ahead
I think you have the wrong time zone selected. Some zones are 30 min. off the rest. just in case
Instruction book page E-23. To turn auto receive on or off. In Timekeeping mode press D (Lower right) to display last Signal screen. It should say GET at the bottom and show the last time it updated. (Or ERR) Hold down A until the receiving indicator and current auto receive setting (ON or OFF) start to flash. Press D to toggle auto receive on. A again to end.
If you tried to make it receive manually this will be turned off. If the GET screen said ERR then it did not update and auto receive would still be off. I had to do the manual thing about 20 times before it updated. A upper left C lower left D lower right A upper right (light)
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My Casio wave ceptor EQW-M100D has started to show the wrong time, it started with a couple of minutes slow but this has now esculated to 12 minutes slow. This normally happens when the watch is left off...
Aug 31, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I turned off the radio transmitter and cannot turn it back on for time updates. How do I turn it back on?
Thank you for contacting FixYa.<br /> You can actually go to Timex for this at :<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads<br />Best regards.<br /> Jewel
Aug 30, 2010 | Timex T5G341 Sports Radio Control Watch
I accidentally turned off the heart rate, how do i turn it back on/
Thank you for contacting FixYa.<br /> You would be better off downloading a manual from Timex on this one,<br /> <a href="http://www.timex.ca/en/manuals.aspx">http://www.timex.ca/en/manuals.aspx</a><br /> <br /> Best wishes.
Aug 25, 2010 | Timex Ironman Triathlon 50 Lap Digital...
G-Shock Atomic Solar watch - ERR in atomic time keeping
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
Casio atomic watch only has intermittent receive indicator
The receive indicator tells you the strength of the signal when the timing signal was transmitted, (this occurs only during the night).
The strength of the signal dictates how much of the indicator is shown i.e. full strength, full picture, half strength, half picture, no picture, no signal.
Signal strength seems to vary with location (how far you are from the transmitter), so perhaps you are in a poor reception area.
Feb 26, 2010 | Tissot Diver Seastar 1000 T19.1.593.51...
Will not recieve atomic time.My other casio atomic
This watch will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it's self change location in your house. It receives the signal at 0200 0400 and 0600 for the correction.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes2_bing.gif and is best received at night.
Hope this tip helps
David
I have several of the both watches and clocks and love them.
Jan 27, 2010 | Casio GShock Riseman AltiTherm GW92001...
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Timex T5G341 Sports Radio Control Watch Logo
106 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
