Question about Texas Instruments TI-83 Plus Calculator
Darkness to lightness
How to turn form lighter to darker
  • Anonymous Jun 18, 2008
    I changed the Batteries and and now the screen is black when i turn in on, i tried changing the brightness, the screen stays black
  • brat4u09 Dec 23, 2008
    I have already tried changing the contrast and it still has not worked, my screen is still dark, but i can see the cursor it i angle it the right way
Use the contrast which is the 2ND up(darker) or down (lighter)
Posted on Jun 11, 2008
You have to press the 2nd key, then the up or down arrow. up for darker screen, and down for a lighter screen.
Posted on May 13, 2008
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
Dash lights dont turn on
dial could be turned to dimmest setting. try turning the headlights on in the dark or darker inside vehicle and then try twisting the knob counter clockwise or try and find the dimmer switch and see if you can turn the headlights on and turn the dimmer as too see if they come on. if not the check your cig. lighter see if it works it may be a fuse if it does not work as well
Oct 24, 2012 | 2007 Hyundai Sonata 2.4
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
When pressing the on button . goes from light to dark nothing else
Either you need to change the batteries or you need to adjust your contrast. To adjust the contrast, press [2nd] [down arrow] or [up arrow] to adjust it lighter or darker. From your description, it sounds like you need to press the down arrow to make it lighter. Hope this solution helps. Reply back if it doesn't.
Jan 17, 2011 | Texas Instruments TI-83 Plus Calculator
The screen is too dark to read
See if there is a contrast adjustment somewhere on the laptop first, if not then its a possibility your back light has gone and needs replacing.
Jan 19, 2010 | Acer Aspire 3000 Notebook
I accently made my text light black. How do I restore my text to normal?
To alter the contrast (light/dark) of your screen, press "2nd", then press your up and down arrows to make the screen darker or lighter, respectively.
Nov 12, 2009 | Texas Instruments TI-83 Plus Calculator
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Dc12 copier print is some times darker and lighter
i dont understad you problem all rigth, but maybe you need a calibration, see when was the last time
Nov 25, 2008 | Xerox DocuColor 12 Printer
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Please try rephrasing this question. Do you want dark photos to become lighter, or light photos to become darker using photoshop? You are not clear.
Jan 28, 2008 | Adobe Photoshop 7.0 for PC
Texas Instruments TI-83 Plus Calculator Logo
213 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
