Question about Maytag Appliances Over-the-Range Microwave Oven
My Maytag MMV5207BA has this strange glitch or short. Sometimes when you close the door it starts running on it's own, except with no heat. The tray moves and everything. I then realized that if I slightly pull on the handle, it does it. What do I need to do to fix this?
  • 2,272 Answers
Check if the door handle is got loose or if the door handle is got internally loose.If the door handle checked ok.Then check the door closing switch.If there is a short in the door switch/latch wirings then it must be causing the motor in the unit to get command to function automatically.So the tray rotates automatically. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
Does not heat food-master relay reset, all electric OK (fan runs, time & all other settings show OK, turntable rotates), door closed tightly, control lock
THere are three possibilities, open magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor.
Mar 14, 2012 | Maytag MMV1164WB Microwave Oven
Hi. I have a Maytag mmv5207bcs Microwave. Pressed...
mmv5207ba/bc microwave 0 button fan on button does not work all other key pad buttons seem to work
May 21, 2010 | Microwave Ovens
Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkjf
Apr 02, 2009 | Maytag MMV5207BAW Microwave Oven
Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 30, 2008 | Maytag MMV5207A Microwave Oven
Microwave Oven Model MMV5207BA/BC
E13 is usually a bad door switch or door switch mount.
The first step is to unplug it from the power outlet for one minute, then plug it back in and try it again.
If it still fails to heat, I would check the door switches and door switch mounts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Maytag Microwave Ovens
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
83 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
