Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Washer leaking water on the floor....had a code of nf? I have been reading the message boards and they say could be water pressure sensor tube or switch...but where do I fink these in the washer?
  • 526 Answers
If you have water leaking out of the wash tub that sounds to me like it is the issue. How much water is in the wash basket when your Control Board signals the NF (No Fill) error code?
It's time to remove thr front cover and see where the water leak source is. If it's over the Clutch Pulley then you could have a Tub Seal issue. See if you can identify the leak source. Follow all saftey warnings in the Service Manual or call in a repair service........Big Dollars
See this post Clutch Fix I describe in the front of this fix action for dC/uC error codes how to remove the front cover of the machine.
let me know your DIY skills if you want to try a fix. I have many post on troubleshooting the Pressure Switch in the FAV6800A/FAV9800A machines in this forum both under FAV6800AWDIY and dh1200s logins.......D*ick
The Service Manual for reference. Sears Parts Direct for reference.
Posted on Sep 03, 2010
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
I'v washed 3 loads my Neptune washer and twice an message displays nf. What does this mean
It means no fill
Here are some things you can check
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune gets a code of nf.
NF: no washer fill
Washer does not turn on water valves to fill washer with water.
Diagnosis:
May 05, 2010 | Washing Machines
My neptune TL stops at 11 minutes and flashes "nf"
mattscott;
My comments are based on the FAV6800A/FAV9800A.
NF = No Fill. Your machine has reached a Control Board internal timer and has not seen proper signaling from the Pressure Switch for expected water fill for the wash cycle selected.
Possible fail points.
1. Pressure Switch is not signaling for properly tor water fill.
2. Water inlet valve is restricted or not functioning.
Please confirm your machine model number is it a FAV6800A or FAV9800A? I’m going to assume your machine model is a one of those models. Here is a link for the FAV6800A/FAV9800A Service Manual.
If you can let me know how much water is in the wash basket when your Control Board triggers the no fill error “NF” to the display? I would prefer you select Quick Wash cycle with minimal machine settings for the water fill. Do you have the issue with a cold temp select fill, a warm/hot temp select fill?
If you want to DIY I would suggest you become familiar with how to get in Service Mode. We may need to go to page 16 of the SM and possible check for correct Pressure Switch transitions in Board Functional Test Input Control Keys.
We will continue after your feedback…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code nf on display
nf code is no fill ,, washer does not turn on water valves to fill washer with water ,, , chk taps is the water turned on ? check inlet screens on hoses , check wiring connections in harness leading from machine control board to pressure switch,, check water valve ... check inputs and outputs at machine control board ,,
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune TL model #FAV6800AWW
The error code nf is supposed to mean that NO water is coming in. Sounds to me like the water is coming in but the water level pressure sensor tube is either kinked or broken or the sensor itself is faulty. Before doing anything else you should disconnect the tube and blow it out - see if there is a tear or pinhole in it. If the tube is o.k. then you probably need a new sensor. In either case, I would really like to hear from you directly by Email at abehol@yahoo.com .
Apr 02, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
591 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
