Cant turn sound up or down or turn off tv - Televison & Video
    Genius:
  • 1,622 Answers
The problem is from the remote, common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassemble so re-assembly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to…
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo…
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h…
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons on my Panasonic VCR. Once you have completed test with your camera you can use the remote. That's it, I hope you got it going again.
Posted on Aug 30, 2010
Cant find the on manual botton
front panel of TV...........center (ch... up/down.......vol up/down power)
Apr 17, 2011 | Proview PA-32JK1A 32 in. LCD Television
How do I turn off my internl speakers on an RCA model L40FHD41 TV? Nothing in the manual about this.
Some HDTV's have options under the audio/sound settings in your tv's menu. If it is possible to turn your speakers off than that is where you wil find it. However if you cant find it in there another quick solution is to just turn the tv volume all the way down. Why do you need to turn off the speakers?
Nov 30, 2010 | RCA L40FHD41 40. in HDTV
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
May 08, 2010 | Samsung HTC550 Theater System
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Sound probelms with Bush TV
on speakers
built in speakers please tell or i cant help
but if it is on your speakers you just need to tweak them a bit by turning down the treble and bass
Jul 08, 2009 | Electronics - Others
Cant hear sound of drums or guitar through tv when played
Your setting maybe be turned down go to options and then the audio and video settings and turn the insturments back up
Apr 28, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Tv turns on and channel continually scans
Sounds like you have a collapsed channel up or down button, Does each button have a good "rebound"?
if any of the buttons are stuck in, just release them
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My playstation 2 cant display the video but you can hear sound
your first cord that is plugged into the tv is either messed up in the tv then, it is not connected or you yanked the cord instead of getting down and pulling the part about an inch from the tv and messed up the cord internally
Mar 01, 2009 | Sony PlayStation 2 Slimline Console
CANNOT LOWER THE SOUND
dude sounds like if you cant turn down the volume it is an issue with the set your watching it on man!!! This sounds like a trick q???? OMG Ok sorry if its not try to connect to a real tv with a volume control and then the sound will turn down!?
May 09, 2006 | GoVideo DVR4250 DVD Player/VCR
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
