Question about Dell 924 All-in-One InkJet Printer
I changed the ink cartridges and now it just flashes and says clear the carrier jam and press start??? what is a carrier jam and i have cleared everything that can be cleared and it still want work, so please help??
  • Dell Master
  • 4,737 Answers
The mechanism that carries the cartridges is call the carriage (carrier). Remove all the cartridges and reinstall them, now move the whole mechanism with the cartridges installed from it's original position to somewhere and verify that there's no obstructions blocking the movement of the carriage. You can simply open the front access door and move the cartridges to somewhere from where it is now. That'll help you clear the error if there's no physical damage with the machine.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 30, 2010
Clear carrier lexmark x3470m
Pull the power cord to the printer!
Take the paper lid out!
Check inside for jammed paper or other stuff!
Grab the paper with both hands and slowly drag it out whit out taring it!
When everything is clear! put the tray back in and plug in the power cord!
Restart and test to print something!
I hope it helps :)
Jan 14, 2013 | Lexmark X3470 All-In-One InkJet Printer
My printer will not print, keeps displaying ( clear carrier jam! ). How can I fix it?? Do I need to buy a new printer or is this an easy fix. I 've unplugged the printer and checked ink cartridges...
Turn the printer off and unplug it from the wall. Press and hold the power button for sixty seconds. Open the top of the printer to make the ink cartridge carrier accessible. Grab the ink cartridge carrier with your hand and slowly move it back and forth until it moves freely. Then plug the printer back in and turn it on. That should solve your issue.
Sep 25, 2011 | Dell V305 All-In-One InkJet Printer
Lexmark x2600 is blinking ej
The EJ error on your printer indicates that your ink cartridge carrier has stalled. Open the printer cover and clear the mechanical jam, then press the power button. Try to reseat your cartridges and make sure it's properly inserted in the carrier.
Apr 04, 2011 | Lexmark X2600 InkJet Printer
V305 print has a message "clear carrier jam" ?can't figure this out. help
the carrier is the part the holds and moves the ink cartridges, I would open the printer like you are going to change the ink and remove and replace the cartridges ... if the carrier does not move when you open the printer then give it a gentile nudge and see if it will move
Mar 24, 2010 | Dell V305w All-In-One R840635AU InkJet...
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
2. Repositioning the Encoder strip.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
336 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
