Question about Frigidaire Affinity ATF7000EG
I HAVE A FRIGIDAIRE AFFINITY DRYER - MODEL NUMBER: AEQ7000EGO \r\nTHE TUMBLER TURNS BUT THERE IS NO HEAT. I'M TOLD IT MAY BE A FUSE, WHERE IS A DIAGRAM WHERE I CAN LOCATE THE FUSE THAT NEEDS TO BE REPLACED
SOURCE: broken tumbler belt
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
Posted on Jan 03, 2008
SOURCE: Frigidaire Affinity dryer error code?
I have an affinity dryer that has dn displaying on the in the digital read out what does this mean
Posted on Aug 29, 2008
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
  • 57 Answers
SOURCE: frigidaire affinity dryer makes buzzing noise when
your motor is out you need to replace it
Posted on Mar 04, 2009
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Where is fuse on frigidaire aeq7000ego
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Dryers
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The dryer is a frigidaire model aeq7000ego and it doesnt put out any heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Frigidaire Dryers
Frigidaire dryer AEQ7000EGO not heating up
you need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Sep 12, 2009 | Frigidaire AEQ7000ES Dryer
No heat
Check your breaker box, or fuses. A dryer will run but not heat if one fuse is bad.
Sep 28, 2008 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Affinity ATF7000EG Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
