Question about Cycling
The chain on my scooter keeps on falling off.
  • 718 Answers
If there is no adjustment in the rear wheel, to pull the wheel back and tighten chain then you will need to cut out a couple of links and reset tire and chain or by new chain for that scoot because your chain is stretched buddy!!! Good Luck
Posted on Aug 30, 2010
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
I have a problem. With my chain every time I put it on my scooter it keeps on falling off when I ride it.
You need to adjust the bike to the chain. That is why there are chain adjusters on the swinging arm.
Oct 10, 2013 | Motorcycles
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Razor e200 scooter the chain tensioner spring - where does it attach?
tensioner should fit on axle or behind the axle on the edge of thew fork where hardware should be mounted to adjust tensioner
Jun 10, 2012 | Razor E200/300 Electric Scooter Battery
I'm having trouble keeping the chains on my John Deere Tractor. I put them on exactly how the diagram said. They seem pretty tight but they keep falling off when I get out there during snow removal. ...
you need to make shure the chains fit the tire snug and then you need to put a rubber tension band (they usually don't come with the chains) you can get them at a walmart or auto parts store, about $2 for 2 of them and come with little s hooks that you secure to the chain, instructios are on the package, the rubber band you put on the chains on the outside of chains and it keeps tension on the chains so they won't be lose and fall off. hope this helps.
Jan 12, 2011 | John Deere 22 In. Rear Tire Chains
Chain keeps falling off
Have you stripped the studs that hold the guide bar in position? It is the only thing I can think of unless the guide bar has worn down so much there isn't a deep enough groove to guide the chain
Jun 01, 2010 | Poulan Pro Chain Saw 46cc 20"
The chains keep falling off the tire. What have
let all the air out of the tires before installing chains. Then install chain as tight as possible then inflate tire this will get chains on tighter.
Dec 27, 2009 | John Deere 22 In. Rear Tire Chains
Razor Electirc Scooter, the chain keeps falling off, I cannot see how to tighten it....help
If the chain is too long than shorten it by using a chain breaker. Or you don't have a chain breaker take the scooter to a bike or more preferable a electric scooter shop and have them do it. The problem could also be your chain tensioner check to see if it's tightening the chain.
Dec 17, 2009 | Razor E100 Electric Scooter
Chain falls off Poulan PP3516AVX
The bar needs to be adjusted. What this means is the long, sliver arm that sticks out and has the chain wrapped around it is in too far. You will need to find what is called a 'set screw' or 'set bolt', which you can loosen and then adjust the bar in and out, which will tighten or loosen the chain. Keep in mind that you should have a little slack on the chain or you will burn up the bar. Also, make very sure that the chain is good shape. A chain that pops on you can take an eye out or fingers off of your hand if you're not careful.
Jun 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Cycling Logo
94 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
