Question about Gateway 500GR PC Desktop
My gateway ev500 says system halted ive done the f8 it will not boot boot failure exitiing intel pxe rom ive checked the cable too help
  • Gateway Master
  • 11,800 Answers
The hard disk has died - replace it and reinstall.
Posted on Aug 30, 2010
Testimonial: "Im not a computer genius.Im a better troubleshooter,meaning Im from 'the generation of Im going to try to fix this"But getting a answer alone makes me"
My computer says check cable connection PXE-MOF:exitiing intel PXE ROM. no bootable device--insert boot disk and press any key. What does it mean, and how do i fix this?
Check your bios and make sure that your boot from lan is disabled, and check the boot order. Make sure that your CD rom is first, then your hard drive, then boot from lan. Boot from lan needs to be one of the lasts you use if you use your laptop for personal use.
Also make sure any USB devices, like flash storage or external hard drives are disconnected from the computer.
May 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check...
You probably have the bios set to boot from a network, instead of the hard drive.
Find out how to get into your bios as the computer is booting (maybe F8, maybe ctrl-s?) then change the boot order to HD first, followed ny C D-ROM, followed by floppy, then network LAST.
FiOS-Dave
Aug 15, 2010 | Computers & Internet
My laptop says PXE-E61 : Media
reboot your laptop , read the screenwhen it says press ? for boot menu
press (f8) for bios
press the one that says boot menu and then when it asks you where to boot choose the one that says hard drive. when that boots up and works. you need to restart your pc and press the f8 one to go into bios, then go to the boot tab, and change it to boot 1st from your hdd. somehow it got changed and it is looking somewhere else for the boot directions and its making errors
Jul 31, 2010 | Gateway MT3705 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Boot failure: System Halted
if you know how to reset your rom chip you can get your computer running again your computer is set to boot from a remote main frame and its looking for those files which boot system with mainframes harddrive not yours
theres one other way to correct this problem go inside bios from bootup
and reset settings
Jun 26, 2009 | Gateway 700 XL PC Desktop
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Pxe e53 no boot filename recieved,
check your harddisk is detected or not in bios setup
Apr 05, 2009 | Gateway Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Gateway 500GR PC Desktop Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
