Question about Toshiba DR410 DVD Recorder
I have a toshiba dvd video recorder. The problem is the initial setting wont come up so I can set it to english, everything thing comes up in spanish. Model# D-KR10KU
  • fkuehling Aug 31, 2010
    When I press setup with the remote ajuste general comes up, and all the settings under it are in spanish. I am using the original remote and manuel, like I said before initial setting never comes up, for me to hit english.
  • fkuehling Sep 01, 2010
    No, in so many words I should learn spanish
  • Toshiba Master
  • 5,426 Answers
Press Setup on the remote > General Settings (the first option down) > Display (the second option in this list) > OSD Language *the first line) and choose your language (English should be the first in the list). Use the up/down arrows to change lines followed by Enter to select the option.
If you are using a universal remote that doesn't have the setup button that works, you need a different remote. Remotes.com has a new remote almost identical to the one that came with the unit as well as used remotes. http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12832146296260&smodel=DR410&brand_pn=TOSHIBA_DR410 .
I hope this helps.
Posted on Aug 31, 2010
  • 5 more comments
  • Cindy Wells Aug 31, 2010
    BTW, press Setup again to exit the Setup menu.
    The Spanish labels are in the same place which is why I gave the order in the lists.
    ajuste general = general adjustment
    Literal translations would be:
    Sistema General = General Setup
    Demostración = Display
    Lengua de OSD (if the abbreviation is kept)
    En Pantalla Lengua de Demostración (otherwise) = OSD Language
    Inglés = English
    I hope this helps.
    You are seeing the Setup screen (ajuste inicial) that you need. You just need to find the appropriate line even if it is in Spanish. Most of the time there will be one word that will be similar to the English
    like general/general, Language/Lengua.
    I hope this helps.
    There must be a reason why I cant program it in english,, this doesn,t solve my problem. Somebody out there must know whats causing. Why should I have to translate it back to english, Thanks for nothing
    I can't tell you why the unit is set for Spanish On-screen Display. I can only tell you that you can change it back to English - it has only a few language choices. Three steps: press Setup. On the first screen, choose the first line by highlighting it (the word general will be part of the text) and press Enter. On next menu screen, choose the second one down (Display/Demonstracion) and press Enter. Select the first line for OSD Language (Lengua in Spanish) and press Enter. Finally select English which should be your first choice (in Spanish it reads Ingles). Press Enter and then Setup to exit the menu.
    After that all your OSD menus should return to being in English.
    (all of my units have options for French, English and Spanish menus. Swapping them is easy and is a simple way for someone to practice their second and third language skills when they want to.)
  • Cindy Wells Sep 01, 2010
    You need enough Spanish (mostly words that are very similar in both languages) to reset the unit. Then you can put it into English and leave it there. After that you can forget the Spanish. (Alternatively just reset it by the places in the menus and ignore the Spanish.)
  • ronf57
    ronf57 Nov 05, 2012
    use google translate to translate what is being displayed from a computer browser type: translate.google.com set the left window for spanish and enter what is displayed on the screen in the window. on the window to the right set it as english and click the translate button to see the translation in the right window. hope this helps.
We have a Philips DVD Recorder a Freeserve Digital box and a TV. Since adding the DVD Recorder we cannot tune in Freeserve at all and DVD's play only in black and white. Help Please. ...
Hi Jack,
And if you remove the DVD Recorder, everything is back to normal?
Initially, I would suspect that your DVD is set to PAL system and not to NTSC (or could be the other way around). Could you pls post back with the exact model number of the Philips DVD Recorder?
Additionally, could you pls detail how the Freeserve Digital box is connected to the Philips DVD Recorder and then to the TV? Pls indicate if you are using Video IN/OUT, S-Video, HDMI, SCART, RF IN/OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
Unable to perform initial settings
Manually select MENU or SETUP on the remote.
Dec 28, 2012 | Toshiba Dr430ku Dvd Recorder - Black
Cannot record on Toshiba DVD Recorder
Sounds silly, but are you sure you have a DVD in the slot? It probably won't let you record video on a CD. (From experience, that is an easy thing to do.) The second thing I would check is to make sure the connections are correct, and the plugs fully inserted. Things can work loose. If there is no signal coming in, it cannot record. Unplug it for 30 seconds or so, then start over.
Jan 03, 2018 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
When I turn my Toshiba D-VR4 recorder on, it won't go to DVD
I figured it out with absolutely no help from the manual. To initiate recording, you have to press the timer/set button. After the DVD recorder finishes recording, you have to re-press the timer/set button to take it out of recording mode. I think their book needs to explain that more clearly.
Sep 29, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Taping to VCR from Camcorder
If the camera is attached to the VCR using the yellow, red & white RCA cables or the S-Video cable, then the VCR has to be set to AV or Video IN.
On the otherhand, if the VCR is connected through the RF OUT to the TV's ANT/Cable/RF IN, then the TV has to be set at either Channel 3 or 4.
May 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Toshiba DR410 DVD Recorder Logo
337 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
