Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Loud click,compressor starts, immediately stops. Then a click ,fridge light dims for a couple of seconds. compressor starts and continues to run. Fridge cooling ok.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
The fridge stopped working last night. The light works, but the fridge just makes this clicking sound every couple of minutes, doesn't sound like anything is running and it does not get cool at all. Any...
Not a good sign, clicking. Usually that click comes from the compressor power circuit. The compressor is attempting to start but it does not. The clicking is from an overload protector that heats up from current draw. It clicks and cuts the power to the compressor, cools down, and the cycle starts again. Could be a start capacitor went bad, but it is probably the compressor.
Mar 11, 2015 | Refrigerators
Fridge and freezer stopped cooling...light stays on, cleaned coils, drain not clogged...fan is working...hear a click about every 3 minutes, light goes dim for about 10 seconds...another click, lights back...
the click is the compressor trying to start . i would replace the relay and compresser over load . . they do go bad and this is what happens . .. mm hope this helps .. feed back pls ..
Jul 10, 2011 | Kenmore Refrigerators
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer not cooling
Hi, If the lights are dimming, the compressor is drawing to many amps when trying to start. If the refrigerator is under 5 years old, I would check into the warranty. If it is over 5 years, You will be better off to get a new refrigerator.
I hope this gives you an idea on what is happening.
Vic
Jun 27, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
Compressor is trying to start
can be or the capacitor thats the one do the first push to te compressor to start it
Dec 27, 2007 | Kenmore 72073 Top Freezer Refrigerator
Running but not collecting water...
Sorry to be vague in advance. I am a bit confused as to the compressor seems to be running bit. If the unit is on you should hear the compressor making a continuous noise. What you have described over a relay going click every fifteen secs could be the compressor overload / relay. If it is then the compressor is trying to start hence the dimming lights. Either way I would suggest one of two scenarios either the compressor is faulty or cannot start due to the relay or the unit is short of gas. Eiher way not a good scenario. I would suggest a tech to confirm or spend the money towards a new unit. Hope this helps.
Aug 19, 2007 | Maytag M7DH65B2A Dehumidifier
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
267 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
