Question about Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air - CVG4380W - intermittent sparking
First indication of problem was a tripped GFI outlet on the circuit that powers the stove top. I reset the outlet and I heard the stove fan on with a constant spark. All the burner valves were fully closed. I unplugged the power cord, plugged it back in and the fan stopped but it still sparks (at all 3 locations) every 8 to 10 seconds (much slower than if I turn a burner value to ignite. I suspect the spark relay (I disconnected the yellow wire on top of the relay and it stopped sparking). Any thoughts?
David Dressler - Bend, OR
    Genius:
  • 1,073 Answers
Spark relay malfunction
Posted on May 08, 2008
No power to wall unit
Have you tried plugging anything else in?
Also does the cord have a GFI breaker on it, or is the outlet a GFI outlet, if those are tripped it will keep power from going to the unit. If they tripped more then likely they got wet, or there is a short circuit.
Otherwise if all that is good circuit breaker would be next to check.
Aug 19, 2013 | Fujitsu Heating & Cooling
Reset button ac unit
Hello jerrydj1021 - Often when the breaker trips, it is a mainly because there is too much current running on one circuit. Is the unit plug into a GFI outlet? It is not recommended to use GFI outlets or too many appliances plugged into that one circuit. Try plugging the unit into another direct outlet and see if the breaker trips again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jun 26, 2013 | Frigidaire Heating & Cooling
Frig is intermittently tripping GFI outlet.
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced.
Apr 21, 2012 | Kenmore Refrigerators
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
Purchase new 32'' tv 2-day ago, will not work in a GFI plug outlet trips GFI each time you reset, is there something wrong with unit? works fine in a non GFI outlet
Good News!!! GFI outlets are made to trip when a large amount of power is pulled through them. A GFI is basically a small circuit breaker.Your television set is probably just pulling more amperage than the GFI is rated to handle. That means the GFI is working properly And so is the TV!
May 05, 2011 | Televison & Video
When i plug in my kenmore stovetop the other electrical outlets trip, i unplug it and reset the outlets and the outlet works but i can't use the stovetop unless i light the gas with a match now. what is my...
you, or your electrician has pulled power from one of the gfi outlets to power the electric sparker on the stovetop. If you can figure out which gfi that the power was pulled from, open up the box and find the wire that runs to the stove and remove it from the gfi outlet and connect it to the power before it goes to the gfi.
Dec 26, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
I have a kitchen aid stove gas stove top.had a pro longed power outage(24 hrs) will not ignite auto matically any more must use matches.any suggestions?
check the outlet, perhaps it's its hokked to a GFI outlet somewhere else in the kitchen and the GFI outlet has tripped
Jan 11, 2009 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JGR8850 Gas Kitchen Range Logo
246 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
