Question about Bike Extreme Lite Youth Shoulder Pad
I can't get the bike seat stem to come loose - Bike Extreme Lite Youth Shoulder Pad
    Scholar:
  • 102 Answers
I'm going to assume you that when you say, "bike seat stem" you mean "seat post". I'm also going to assume that the bike frame is made of steel and the seat post is most likely chromed steel.
What most likely is the problem (absent of more details) is that the seat post has rusted to the inside of the frame. If the bike is stored outside this is a very common problem on less expensive bikes.
I have never heard of a bike manufacturer putting any kind of paint or other anti-corrosion inside of the bike frame to prevent rust.
You can try spraying a little "Liquid Wrench" or WD40 oil on the seat post where it inserts into the frame. Let it sit over night and then tap it with a mallet to try to break the rust free. Use a pair of Channel Lock pliers to get a bite on it and see if you can twist it out.
On a steel bike the very last resort to use, if you by all means have to have that seat post out, is to apply heat to it, with a propane or oxy-acetylene torch. This will probably destroy the paint job and weaken the seat post.
If the bike frame is aluminum, you can get something similar to galvanic corrosion and this can seize the seat post in the frame. The remedy is the same as with the steel frame (but excessive heat and easily melt aluminum very quickly and leave a puddle of molten metal on the garage floor). If the frame is carbon fiber and the seat post is aluminum, carbon and aluminum don't like to touch each other and they will start a natural chemical reaction of corrosion which could cause the two to stick together (don't ever use a flame on a carbon fiber bike, it would be the end of the bike and just plain stupid). Anytime aluminum touches carbon or titanium an anti-seize compound should be applied to the parts.
Once you have the seat post removed, use your finger to wipe grease inside the seat tube and on the seat post before reinserting it and you won't have this problem again.
Posted on Apr 15, 2014
How do I rise the handle bars on my nishiki anastazi
Consult a local bike shop for the needed parts and cables.
Dec 07, 2016 | Cycling
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
I need to know what the proper "new" spec for the distance the valve stem should protrude from the head. This is the distance from the head, under the valve spring seat to the end of the valve stem.
I think you are overthinking this Gary.
You get the correct valve for the bike.
You use lapping paste and a lapping tool the seat the valve.
You add the spring, collet and clip.
You adjust the tappet clearance (rocker to top of valve stem).
FWIW, I have never heard of anyone grinding the stem of a new valve. The top of the valve is hardened and you don't want to remove that with the heat of grinding.
Nov 10, 2015 | Motorcycles
Lower seat height
More info required ... what bike? Pedal bike? loosen the bolt on the tube under the seat and adjust the seat stem downward until it will go no more. If it is already in the lowest position, you will have to wait for your daughter to grow a little.
Jun 06, 2013 | Motorcycles
Bike to high
If the big is really too big, then it's not safe to ride, and blocks on the pedals are not a good idea. On the other hand, if you can straddle the frame of the bike with your feet nearly flat on the ground, then the bike is not too big. You can lower the seat, and many seats can also be adjusted forward and back an inch or two. The optimum seat height is when you put one pedal all of the way down, with the heel of your foot on the pedal, then you should be able to lift your weight off of the seat. You can also bring the handlebars closer if the handlebar stem you have has a typical length offset (if you picture the handle bar stem as an inverted hockey stick, the the offset is the length of the hockey stick blade) - if so, you can replace it with a stem with a smaller offset. If the stem already has a very small offset, you can turn it backwards, but don't do this if the offset is more than 1 inch.
Good luck.
Jun 20, 2012 | Schwinn Cycling
Unable to remove seat stem from frame - any sugguetions
Web search it "remove seat stem from frame ". Many postings.
Sep 05, 2011 | Mongoose Maneuver Mountain Bike
My bikes handlebar's keep unloosening I looked at it and the part that keeps the handlebar together is broken. I was wondering how would I fix it cause I looked online on how to change the stem but I...
You are correct that you need to replace the stem, you can not fix a broken stem.
Since you have a replacement stem you may want to take both the bike and the replacement stem into the bike shop and have them do it. It will be fairly quick to replace. There are a number of different types of stems and a couple different diameters that have to be matched up.
The two main types of stems are:
1) type that fits via a neck into the frame
2) type that clamps around the steerer.
You may have a stem that clamps around a steerer. If there are 1-2 screws on the back side of the stem, near the bend, then you have a clamp style. This stem you just loosen the bolts and the top cap and lift straight off. Of course if your replacement stem is not the same type it won't work.
Jan 05, 2011 | Cycling
How do I tighten the stem bolt on the handlebar stem?
If you just need to raise the height of the stem, all you need to do is loosen the hex nut at the top of the handlebar stem with a box wrench or adjustable wrench. This is the head of the stem bolt. Once loosened enough the stem should slide up and completely out (if necessary) of the stem casing. There is a tightening mechanism consisting of two soft metal pieces that tighten against each other when the stem bolt is tightened. When this is loose you can raise the stem to various heights. If you find you cannot raise it to your desired height you may need to replace the stem and bolt. However, if the bike has been sized properly to fit your leg length, you should have no problem there. Once the height of the stem is satisfactory just tighten the bolt while keeping the stem straight and you'll be ready to go!
Oct 30, 2010 | Huffy 26 In Ladies Bay Pointe Bike
I bought a used older model It is a huffy aerocruiser bicycle trailer. has no instructions on how to assemble them onto your existing bike.where does it get attached to and what hardware do you newed to...
While I am no expert, I have a huffy aerocruiser. I also purchase mine second hand, but the woman who sold it to me was excellent on giving instructions at pick-up time! There should have been a peice that fits over the stem of your bike seat and and arm type thing that runs from bike seat piece to the stroller itself. There should also be two clips, a wheel, and a handle. To assemble for bike use, remove your bike seat and place the bike seat adapter piece on the stem of the bike seat then replace bike seat. Use one clip to attach arm to bike seat adapter thing. Use the other clip to attach the arm to the stroller (where the front wheel would go, wheel removed). The bike seat adapter thing remains on the stem of your seat and you just remove the clip that holds the arm to the bike seat when not using the trailer.
To use for jogging, remove the arm and replace the wheel. Slide handle into place and use two clips to hold handle on.
If this requires clarification, please let me know! I may not have made it that clear. I would be happy to take some pictures if it would help!
Best of luck and enjoy your new stroller!
Aug 29, 2010 | Huffy Cycling
I need to raise the height of my handle bars.
I am not sure which question to answer, so I will try both.
raising the handlebars, loosen the stem bolt 4or 5 turns, (this is the bolt on on the top of the handlebar stem). Tap the stem bolt with a hammer, the bold should drop down and the handle bars should fall loose, adjust as needed, then tighten the stem bolt to set.
Please note, there is usually a limit line on the stem, do not raise bars above this level as iy will make the handle bars unsafe and could pull out or break off.
second question, Child seats ar very adaptable, an will fit most bikes. Be sure to use all the necessary hard ware and safety guards. for you and your passenger.
Try to get the seat set up as low as possible as the higher the seat the higher the center of gravity. It will have less effect on handling characteristics if you keep the seat low.
I hope this is of some help.
Ed
Feb 01, 2009 | Schwinn Mesa Gs Mountain Bike
Bike Extreme Lite Youth Shoulder Pad Logo
Top Bike Sport & Outdoor - Others Experts
Are you a Bike Sport and Outdoor - Other Expert? Answer questions, earn points and help others
