Question about Canon PIXMA MP130 All-In-One InkJet Printer
I have a Canon printer i407D that I love, but it came up with a code 807 yesterday and the light flashes from green to orange when I turn it on. Help!!
  • grandmamary1 Aug 30, 2010
    Thanks for the information, but I don't have a Canon Pixma printer I have a Canoni470D printer, will this solutionn work for it too?
  • grandmamary1 Aug 31, 2010
    I don't have the Canon Prixma printer, I have a Canon i470D will this solution work on that printer too?
  • 503 Answers
Here are the official Canon steps to reset:
1-Turn the printer off with the Power button (if available).
2-Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
3-Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
4-Turn the printer back on.
If this is unsuccessful in ridding you of the 807 message, it seems that according to Canon's website
, the only other option is to call or email them as it could be a hardware problem
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Aug 31, 2010
    Genius:
  • 1,478 Answers
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons, each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green. printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow), after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently. If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again. once this done, it should fix the problem.
Take care.
Posted on Aug 30, 2010
  • Jimoh Adeleke Muyideen Aug 30, 2010
    yes, it will, the solution is for your printer model.
Canon i475D is showing error 807
This is basically ink tank error.
You have to reset ink tank
1.Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Thank You
Nov 22, 2010 | Canon i475 InkJet Printer
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Canon i550 printer stoipped printing
    My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
    Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
    Canon i560 Ink jet Error Code 5C00
    1. Turn off printer
    May 05, 2008 | Canon BubbleJet i550 InkJet Printer
    Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
    I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
    Please advice what can I do urgently.
    Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
    Canon i250 flashing orange / green light
    turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
    Feb 17, 2008 | Canon i250 InkJet Printer
    Canon PIXMA MP130 All-In-One InkJet Printer Logo
    89 people viewed this question
    old marine
    old marine
