Question about Maytag SkyBox MBV1976A Beverage Dispenser
Cooling Issue I removed my bev rack and thawed out the ice that formed around the wiring and then plugged it back in leaving it at the halfway point for the temp knob without the rack inside.. The unit is fairly cold and the rear has a noticebly glazed looked but no over the whole area...It seems my compressor is working but maybe low on freon.. What suggestions do you have to get this thing working properly again ... please reply to Mrreaper@comcast.net
  • Asheley Dec 30, 2008
    I had a similar problem a few years back, and the repair man came over and fixed my sky box. Now it has re-curred, and my sky box is no longer under warranty. I Had ice build up on the back of my unit. However, I do not know what he did to get to the back of the unit to rid the ice.
  • 770 Answers
Check your Email
Posted on May 10, 2008
Water is leaking into the fridge from the freezer.It is a top freezer with ice maker
It's likely due to a problem in the defrost drain or a leak in the ice maker. You may be able to solve such problems quite quickly, possibly in just a few steps. Have the owner's manual available to help you find
Some models have a selector switch to allow for a manual defrost cycle. If your freezer has this setting (check your owner's manual), ensure that the switch wasn't set to defrost accidentally. If the freezer was in a defrost cycle, check it in about an hour to ensure it is working.
When the defrost system kicks in, frost buildup on the evaporator coils melts and water is collected in a trough beneath it-more than usual. It is funneled through a defrost drain tube or channel down the back of your refrigerator and collected in a drain pan, where it is then left to evaporate.
Often, the defrost cycle turns off before the water can finish draining, and the refrigerator continues to cool. Ice buildup then forms along the system, and eventually water collects and puddles in the bottom of the refrigerator as melted ice continues to drip from the evaporator coils.
If there is ice buildup, allow the unit to thaw:
1. Remove food from the entire unit, storing it in coolers packed with ice, and remove the freezer shelves. Unplug the unit.
2. Using a screwdriver, remove the panel inside the freezer at the back to access the evaporator coils and trough.
3. Leave open the doors and allow the ice in the trough and along the defrost drain system to thaw by itself. This should take several hours. Note: Keep plenty of towels around and be prepared for the drain pan to fill quickly.
4. When thawing is complete, replace the panel and restore power to the unit. When it is cooling again, replace the food.
For more troubleshooting steps and simple solutions, read Freezer leaking water. I hope this helps!
Sep 28, 2012 | Westinghouse 5303281154 Fridgedaire/wci...
My everstar portable airconditioner is not cooling down my apartment at all, and there is ice forming in the back
Yep its soundss iced up shut it down and leave the fan on if you can. remover the filter and clean it you might have to wait for the ice to thaw from the coil to remove the filter. wash the filter out well set the thermstat to 70 degrees and leave it there, also close any unused rooms if possible check/ wash filter monthly
Jul 19, 2011 | Heating & Cooling
The freezer is not cooling and all items in the freezer have dethawed, The Fridge part is cool but not as cool. This started last night and 24 hours later everything defrosted.
hopefully you still got it plugged up to check a few things.... if so here we go...
1st is there any frost build up on the back wall of the freezer wall inside unit... if so then we know the compressor is still working and you got a defrost problem going on most likely one of these three parts /the heater has failed,the defrost thermostat has failed. or the defrost timer has failed... you can check the heater by gaining access to the back wall of freezer remove shelfs and the remove back panel of freezer there will be a heater down at bottom with a wire on each side make sure the unit is unplugged at this point and that you take a hair dryer and thaw ice test heater on each side with a meter checking for contuinity through heater to make sure no broke... the defrost thermostat is mounted to the coil in same area prior to thawing gain access to wires if there is ice around thermostat which is round and clips to coil has 2 wires again unit unplugged adn prior to thawing check for contuinity as if there is ice around it it should have closed... if both them are good you most likely have a bad defrost control/timer. if there is no ice on back panel is the fan in freezer section working when the door switch is closed listen ,is the fan in the back of unit working ,is the compressor running have you heard any clicking coming from back of unit if so that would indicate a bad compressor relay on will require to be replaces.... not much description in your post but hopefully one of these tips help you get a diagnoses. good luck
Jan 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Not cooling
Cooling fan, behind internal plasic panel is frozen up, happens with me regularly, self defrost function not working properly, i'm just fixing mine as I write. I have found that bottom drain hole was all full of ice also. Have cleared with anti-freeze/hot water till runs through. Take out all shelves, remove back panel, there are screws behind chrome bezel and also inde-odoriser recesses (those two square plastic covers). Unscrew plastic water chiller, be careful not to damage pipes. Remove the back platic moulding, unclipping wire connectors and cooling fan is fastened to back, it will be frozen up with ice! I use hair dryer/ de-icer to thaw, dry off as much as possible. Beware, moulding is mainly polystyrene, i.e fragile. I suspect that I keep getting problems because I didn't clear out the bottom drain hole, so it did not defrost. Tell tale sign is noisy fan (hitting ice) which eventually freezes up and stops blowing cold air which causes fridge to stop cooling, compressor still works though!
Jul 23, 2009 | Samsung RS2630SH Side by Side Refrigerator
In the frezzer ice is forming under the floor and dripping down onto the floor of the refrigerator part under the veg drawers
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
May 05, 2009 | Kenmore Refrigerators
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Need to unplug drain tube in 2005 roper fridge I have a Frigidaire frs26zgh. I have ice buildup in the bottom of the freezer too. I pulled everything out of the freezer including the shelves and the back...
you can thaw it out by pouringboiling water down the drain trough, or use a hairdryer to assist you, ( i actually use the steam machine bought form the t.v.) afte clearing the ice, water will flow down the tube normally
Nov 09, 2008 | Refrigerators
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
59 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
